602a Posted September 25, 2010 Posted September 25, 2010 Anyone own either of these? If so how do they sound for blues and southern rock? None to be found in Baton Rouge to try out.
smurph1 Posted September 25, 2010 Posted September 25, 2010 Anyone own either of these? If so how do they sound for blues and southern rock? None to be found in Baton Rouge to try out. I've played through a Delta Blues..Nice Amps..But, I bought a Classic 30.. Nice Clean Tone, Great Reverb, and SWEET tube overdrive!! Plus it was only $600 brand new!! My H-535 Loves it!!
Steiner Posted September 25, 2010 Posted September 25, 2010 I've played through the Delta Blues. There's a large amount of fun there for the cost!
kbp810 Posted September 25, 2010 Posted September 25, 2010 I've played through the Delta Blues. There's a large amount of fun there for the cost! I've spent a little quality time with the Delta Blues as well, it's a nice sounding amp Both have a really great tone to cost ratio going on, so either is likely to be a very safe bet!
FrankV Posted September 25, 2010 Posted September 25, 2010 I picked up a Peavey Delta Blues a couple of months ago, and I'm loving it. Nice clean, plenty of crunch with the gain; it's got reverb which is very nice at a lower setting, 1-3; and a tremolo which I don't use. Yet. I got mine used for $400. Not a great bargain, I think they go for 6 something brand new, but I was jonesin' for a tube amp, and grabbed pretty much the first one I liked and could afford. It's got a honkin' 15" speaker, and cranks if you like it loud. 30 watts. I'm still learning it, believe it or not, but so far it gets all the sounds I'm looking for. It's got bass, mid, treble knobs; and a 'boost' button which I don't use. The 535 sounds great with it, and just yesterday I picked up the Strat again, and it's sounds real good too. What a difference between the two guitars, sound wise! For the moment I'm keeping the 535 tuned half a step down, and the Strat standard. I'm trying like hell to get SRV into my fingers.
602a Posted September 26, 2010 Author Posted September 26, 2010 Yea I'm Gary Moore in my mind but my fingers won't follow.
slider313 Posted September 26, 2010 Posted September 26, 2010 I had a Delta Blues with a single 15" that I picked up locally from a Craigslist add a couple of years ago. Not a bad amp but it seem el84 amps and I don't get along. I feel most, if not all, builders run these tubes too hot and, even with a fresh set of tubes, after a few weeks of regular playing the sound seems to change/suffer. Check out prices on used Ampeg Reverberocket "reissues". They're not really reissues but the 1x12 50 watt version uses a pair of 6L6's and are a great bang for the buck.
602a Posted September 27, 2010 Author Posted September 27, 2010 I had a Delta Blues with a single 15" that I picked up locally from a Craigslist add a couple of years ago. Not a bad amp but it seem el84 amps and I don't get along. I feel most, if not all, builders run these tubes too hot and, even with a fresh set of tubes, after a few weeks of regular playing the sound seems to change/suffer. Check out prices on used Ampeg Reverberocket "reissues". They're not really reissues but the 1x12 50 watt version uses a pair of 6L6's and are a great bang for the buck. Thanks I'll check them out.
Gitfiddler Posted September 27, 2010 Posted September 27, 2010 +1 for the Delta Blues 115. That amp is like a budget Bassman as far as tone goes. If you are looking for one, be sure it has the metal tube guard to protect those hot valves.
602a Posted September 27, 2010 Author Posted September 27, 2010 Will do. I am checking on a Ampeg Reverbrocket right now. There is a guy here that wants to sell a Classic 30 for 200. I might jump on that.
smurph1 Posted September 27, 2010 Posted September 27, 2010 Will do. I am checking on a Ampeg Reverbrocket right now. There is a guy here that wants to sell a Classic 30 for 200. I might jump on that. Go play it, if you can..
602a Posted September 27, 2010 Author Posted September 27, 2010 Go play it, if you can.. I can't, it's in Chicago, but for the price 325.00 + 65 shipping I may give it a try. It's either that or a Peavey classic 30 with weber and jj upgades for 400
jrfreed Posted October 1, 2010 Posted October 1, 2010 I can't, it's in Chicago, but for the price 325.00 + 65 shipping I may give it a try. It's either that or a Peavey classic 30 with weber and jj upgades for 400 This is the route I went with my c30. Weber Chicago, beam blocker, and NOS tubes and the thing charged back to life. Especially once the speaker started to break in!
