Sparky Posted October 14, 2010 Share Posted October 14, 2010 I've got an 8 ohm output on my Behringer GM110 combo (Chinese Tech21 30 Watter), and I'm looking to power two 16 ohm 1x12" cabs with it. Can I use a "Y" cable from the single output to the two cabs? I bought two of those Epiphone 1x12" Valve Junior cabs for a "c" note each... birch cabs with a 70 watt Eminence speaker. They look pretty good too, once I figure out how to remove the "Epiphone" logo. They don't seem to screw 'em in anymore. Link to comment Share on other sites More sharing options...
mars_hall Posted October 15, 2010 Share Posted October 15, 2010 I've got an 8 ohm output on my Behringer GM110 combo (Chinese Tech21 30 Watter), and I'm looking to power two 16 ohm 1x12" cabs with it. Can I use a "Y" cable from the single output to the two cabs? I bought two of those Epiphone 1x12" Valve Junior cabs for a "c" note each... birch cabs with a 70 watt Eminence speaker. They look pretty good too, once I figure out how to remove the "Epiphone" logo. They don't seem to screw 'em in anymore. Sure just make sure the + or red terminal on both speakers go to the center lug on the jack. In other words, don't have the + (RED) from one speaker going to the same terminal as the - or black terminal from the other speaker. This will cancel out certain frequencies (bad). Link to comment Share on other sites More sharing options...
mars_hall Posted October 15, 2010 Share Posted October 15, 2010 . Link to comment Share on other sites More sharing options...
TalismanRich Posted October 15, 2010 Share Posted October 15, 2010 I've got an 8 ohm output on my Behringer GM110 combo (Chinese Tech21 30 Watter), and I'm looking to power two 16 ohm 1x12" cabs with it. Can I use a "Y" cable from the single output to the two cabs? I bought two of those Epiphone 1x12" Valve Junior cabs for a "c" note each... birch cabs with a 70 watt Eminence speaker. They look pretty good too, once I figure out how to remove the "Epiphone" logo. They don't seem to screw 'em in anymore. Make sure you wire up the cable in parallel. A "Y" cable with both speakers lines coming off the same point will do that. Putting 2 16ohm speakers in series would be 32 ohms. Link to comment Share on other sites More sharing options...
Sparky Posted October 15, 2010 Author Share Posted October 15, 2010 Thanks for the help dudes. Link to comment Share on other sites More sharing options...
