Guido Posted October 25, 2010 Posted October 25, 2010 Does anybody know how to find out the pot values of my H-150? It's from 1993. The values are not written on the pots. Maybe somebody knows if they use standard values or if they just use what's on hand? Thanks
kbp810 Posted October 25, 2010 Posted October 25, 2010 Does anybody know how to find out the pot values of my H-150? It's from 1993. The values are not written on the pots. Maybe somebody knows if they use standard values or if they just use what's on hand? Thanks Usually Humbuckers use 500k pots - most likely that is what they are Sometimes it's also printed on the front upper portion of the pot (common with Alpha pots) -otherwise, you could always de-solder one and check it with a meter
Guest HRB853370 Posted October 25, 2010 Posted October 25, 2010 Does anybody know how to find out the pot values of my H-150? It's from 1993. The values are not written on the pots. Maybe somebody knows if they use standard values or if they just use what's on hand? Thanks I would say at first guess, top shelf Columbian, but if not, Jamaican would be a close second!!
Spectrum13 Posted October 25, 2010 Posted October 25, 2010 Usually Humbuckers use 500k pots - most likely that is what they are Sometimes it's also printed on the front upper portion of the pot (common with Alpha pots) -otherwise, you could always de-solder one and check it with a meter From 2006 -2009 they used WD pots and the values on three of mine were all 250 volume and 250 tone. Unfourtunatly you might need to disassemble to test and/or view the assumed values to know for sure.
Spectrum13 Posted October 25, 2010 Posted October 25, 2010 I would say at first guess, top shelf Columbian, but if not, Jamaican would be a close second!! Will, Guido lives in Germany. Different distribution network.
Guest HRB853370 Posted October 25, 2010 Posted October 25, 2010 Will, Guido lives in Germany. Different distribution network. oops!
Guido Posted October 26, 2010 Author Posted October 26, 2010 Will, Guido lives in Germany. Different distribution network. That's right! Here in Europe it's mostly from the Netherlands.
