glaister Posted November 1, 2010 Posted November 1, 2010 Hello all,I`ve owned an `88 H 170 for a number of years,but only recently found you guys here.The newer H 170`s shown here seem to differ in shape/specs from my own,what has been changed and when were these changes made? Thanks.
FredZepp Posted November 1, 2010 Posted November 1, 2010 Heritage H 170 Specifications : Neck : 17 degree peghead pitch; one piece mahogany neck. Fingerboard : 24 3/4” scale rosewood fingerboard with 22 frets; mother of pearl position markers. Body : Double cutaway; solid body with solid carved curly maple top and mahogany back; cream bound top; with cream pickguard. Body Size : Rim Thickness - 1 1/2” Body Width - 12 1/2” Body Length - 17 1/4” Electronics : Two humbucking pickups with exposed coils; two volume and one master tone control with selector switch. Hardware : Chrome plated hardware. H 170 - Same as H-170CM except with 2 Seymour Duncan Stag Mag pickups with two push-pulls for volume, humbucking and coil-tap selections.
brentrocks Posted November 1, 2010 Posted November 1, 2010 Welcome! the bodies on the H 170s now are thicker, the horns are more rounded....i think those are the 2 big differences
glaister Posted November 2, 2010 Author Posted November 2, 2010 Thanks,I`m also seeing a totally different neck joint,more akin to a dc lp junior,whereas my own is done more like a Vee. The newer horns look plain ugly to me,why was that done?
FredZepp Posted November 2, 2010 Posted November 2, 2010 Here is an '86 H170 for comparison.. or an '85.. new H-170.. The H-140 went through the same evolution of the shape of the horn....
Gitfiddler Posted November 2, 2010 Posted November 2, 2010 Looks like the newer models had their wings clipped. I agree. The older version looks better to me as well.
koula901 Posted November 2, 2010 Posted November 2, 2010 Yeah, I gotta agree - I think the pointier horns do look better - more modern.
tbonesullivan Posted November 2, 2010 Posted November 2, 2010 did they change the horns on the H170 at the same time they changed them on the H150 to avoid problems with Gib$on?
tulk1 Posted November 2, 2010 Posted November 2, 2010 Looks to me like the original model H170 is a double cut H140. Current model H170 is a double cut H150. And since the current model H140 is a smaller version of the H150, it follow that the H170 would look like the H150/H140. Only double cut ................ or something like that.
Gitfiddler Posted November 2, 2010 Posted November 2, 2010 did they change the horns on the H170 at the same time they changed them on the H150 to avoid problems with Gib$on? That may be correct, but it makes no sense to me since the original 170 looked more like an Ibanez Artist than a double-cut Gibson.
smurph1 Posted November 2, 2010 Posted November 2, 2010 That may be correct, but it makes no sense to me since the original 170 looked more like an Ibanez Artist than a double-cut Gibson. +1 on that.. EXACTLY like the AR-300 I used to have..
smurph1 Posted November 2, 2010 Posted November 2, 2010 Heritage H 170 Specifications : Neck : 17 degree peghead pitch; one piece mahogany neck. Fingerboard : 24 3/4” scale rosewood fingerboard with 22 frets; mother of pearl position markers. Body : Double cutaway; solid body with solid carved curly maple top and mahogany back; cream bound top; with cream pickguard. Body Size : Rim Thickness - 1 1/2” Body Width - 12 1/2” Body Length - 17 1/4” Electronics : Two humbucking pickups with exposed coils; two volume and one master tone control with selector switch. Hardware : Chrome plated hardware. H 170 - Same as H-170CM except with 2 Seymour Duncan Stag Mag pickups with two push-pulls for volume, humbucking and coil-tap selections. The horns may be a bit ugly, but (as usual) the finish is gorgeous!!
big bob Posted November 2, 2010 Posted November 2, 2010 That may be correct, but it makes no sense to me since the original 170 looked more like an Ibanez Artist than a double-cut Gibson. But if you change the Jig for the 150, you change the jig for the 170. (cutting/routing jig) that is
tulk1 Posted November 2, 2010 Posted November 2, 2010 Or ... maybe they've just moved away from the sharp, pointy horn era of guitars. Except for the Anniv H140, that is.
