MartyGrass Posted November 26, 2010 Posted November 26, 2010 How can I change the wiring on my double HBs so that there is a smooth volume and tone roll off? Also, I'd prefer when both pups are on to not let one volume control serve as a kill switch for the other pup. Is that possible? I hope this makes sense. Really, I'd like the knobs to do what they intuitively should do and not a damned thing more. Thanks.
mars_hall Posted November 26, 2010 Posted November 26, 2010 How can I change the wiring on my double HBs so that there is a smooth volume and tone roll off? Also, I'd prefer when both pups are on to not let one volume control serve as a kill switch for the other pup. Is that possible? I hope this makes sense. Really, I'd like the knobs to do what they intuitively should do and not a damned thing more. Thanks. Are they currently wired as a master tone with two separate volume controls?
mars_hall Posted November 26, 2010 Posted November 26, 2010 Assuming 2 Volume and 1 Tone, this should be it ignoring the battery and the pots would be 500K. Check for color coding. Sleeve and ring are soldered together.
MartyGrass Posted November 26, 2010 Author Posted November 26, 2010 Are they currently wired as a master tone with two separate volume controls? The 170 is that way. The Millie and the 150s have two tone pots.
MartyGrass Posted November 26, 2010 Author Posted November 26, 2010 More info Well, that link is informative. I'll leave things as they are. Thanks.
