Pickguard bracket screw size?
sick1982
Hi all!
I'm looking for a new screw that holds the pickguard bracket in the body, because it is a bit scratchy and about to loose all screwdriver grip.
Someone knows which size it is and/or where to get one (in Europe)? I'm not very eager to get it out and waiting for a replacement to arrive :-)
Thanks for any tips!
Kind regards.
don't fret, a screw is a screw, you don't need a special one. If the hole is stripped, and the screw won't 'bite', take a small piece of toothpick, put a little glue on it, stick it in the hole, and then your screw will have something to grip. Just a tiny piece of wood, dabbed with a bit of glue, problem solved.
Hi frank, thanks for your answer!
But I actually meant the 'carve' where you put the screwdriver in is worn out, not the hole where the screw goes in :D
I was looking for the diameter (including thread) and length of the screw, so I can find a good replacement before attempting to get the current sucker out :D
Knowing the stores near my location, they will likely have everything except what I really need and want it to be :blink:
I removed it (clearly for the last time) and thought sharing in case anyone ever would want to replace one too:
- Thread length: 10mm
- Thread diameter: 2mm
- Head length: 2mm
- Head diameter: 4mm
- Head type: mushroom
