Anyone coil taped HRWs?
CJTopes
I Believe that my HRWs have 4 wire leads. Any opinions on coil taping HRWS and the results? I'm think about doing this on my Millie DC. Any recommended pots or caps to use.
The PSPII White Boy H555 Custom came with coil taps for both pickups. It does a VERY convincing single coil. Especially for a semi-hollow. Gets very Tele-ish. Not sure what pots or caps are used in the Heritages, but it sure seems to work.
Ok here it is... I believe without double checking the yellow and green lead are tied together and isolated in an HRW 4 lead standard wiring... This gives you the full humbucker in series. Take those 2 wires to the middle lead on a push pull pot, ground the bottom lead on the same side terminal as the one you used(there are 2 sides of 3 terminals by the way) .... you are done, its that simple. Pulling up on the pot grounds the yellow and green eliminating one coil!
Thanks a lot. Very Helpful. I'm having issues with one of the Vol Pots so I may just replace them all since I'll be in there anyway.
Oh man, not another one. I'm hearing a lot of jaw flapping from Bears fans lately. You'll need the "power of Ditka" to beat us in Lambeau.
I was just looking at pots at Mojotones site. I'm assuming I would use a short post on a Millie?
