H Posted May 11, 2011 Author Posted May 11, 2011 OK, wood done, time for the electronics. At the weekend, I looked through all the stuff I got in the box from Tube Amp Doctor (TAD) and ticked it off against the parts list. I realised that the resistors used a colour code to show their rating and had to look that up so I could label them in bags for easy reference. I put a few of the bigger components loosely on the eyelet board to get an idea of how tight it would be for space when I'm soldering. Tonight I did a bit of drilling on the chassis to create a mount point for a terminal strip and loaded up the power transformer, valve bases, input and output jacks, standby and power switches, fuse holder and pilot light (still red for now). I finished off with the pots and then put it all back in the box I got the original Fender schematics/wiring diagrams and realised that the TAD kit isn't wired exactly as the Fender 5E3. It's pretty close but there are differences. I wonder what difference that will make tonally...
mooonpi Posted May 11, 2011 Posted May 11, 2011 If the changes are around the power supply it may just be upgrades to modern safety standards.
DetroitBlues Posted May 12, 2011 Posted May 12, 2011 That sure seems complicated. Makes you wonder how they figured it all out originally....
Steiner Posted May 14, 2011 Posted May 14, 2011 That's a classy looking amp H. You have done very well!
pegleg32 Posted May 14, 2011 Posted May 14, 2011 I can't find a thing not to like Howard - looking very nice indeed.
DetroitBlues Posted May 14, 2011 Posted May 14, 2011 Its amazing how so many of us absolutely love these Fender clones, but it makes me wonder why so few Marshall or Vox clones?
H Posted May 14, 2011 Author Posted May 14, 2011 Its amazing how so many of us absolutely love these Fender clones, but it makes me wonder why so few Marshall or Vox clones? Complexity of the circuits maybe? There are a few Marshall 18W Bluesbreaker clones out there but you're right, not much to choose from.
H Posted May 14, 2011 Author Posted May 14, 2011 Some more electronics today too Fitted the rest of the components to the eyelet board and straightened out the legs ready for cutting. Used a tiny bit of solder to 'tack' the components before the main wires are attached. Soldered the various resistors and capacitors to the pots, jacks, etc.
kbp810 Posted May 15, 2011 Posted May 15, 2011 Shouldn't be too long now and she should be ready to rock! Are those Alpha pots? looks like you did the right thing by sanding the surface a bit, but you might want to do a couple of good tug/push tests on those contacts to make sure they're solid. I like using Alpha pots in amps, but I generally run a ground bus as opposed to grounding to the casing itself when using them.
H Posted May 15, 2011 Author Posted May 15, 2011 Are those Alpha pots? looks like you did the right thing by sanding the surface a bit, but you might want to do a couple of good tug/push tests on those contacts to make sure they're solid. I like using Alpha pots in amps, but I generally run a ground bus as opposed to grounding to the casing itself when using them. Yes, they're Alpha pots. The connections are pretty solid I'm inexperienced with this kind of layout so I'm following a wiring circuit supplied with the kit, hence the lack of a ground bus. A question: I have to test the circuit at various points when it's complete. Do you know of a good picture-based resource for the various tests I'll need to perform?
kbp810 Posted May 15, 2011 Posted May 15, 2011 Yes, they're Alpha pots. The connections are pretty solid I'm inexperienced with this kind of layout so I'm following a wiring circuit supplied with the kit, hence the lack of a ground bus. A question: I have to test the circuit at various points when it's complete. Do you know of a good picture-based resource for the various tests I'll need to perform? I'm not sure if there's a picture based one out there, but the Paul Ruby first power up guide is a really good resource (lot's of other good info on the same site as well) Ruby First Power Up
yoslate Posted May 15, 2011 Posted May 15, 2011 Howard, this is as good as, perhaps better than, any project thread I've seen on the HOC in the four years I've been here. The project itself and the documentation have been thorough, articulate, and as much a pleasure to follow as you seem to have had in doing it. What a terrific piece, in both concept and execution! Thanks for sharing this with us! My only problem has been with what a "numpty" this makes me feel like. Congratulations on a job very well (nearly) done! Hope it sounds fabulous!
Hfan Posted May 15, 2011 Posted May 15, 2011 To say the least it is coming out very well Howard. The neatness of your circuit layout is commendable. I was a field tech for many years and none of my work came close to being that pretty although mine wasn't a labor of love. When I add caps to a circuit in an amp I add a little silicon adhesive (GE bathroom silicon caulk in the states) under the caps as a remedy to vibration induced problems. You may have heard of this one..the only time I worked on a total refurb (my old Twin Reverb) I learned of a home made device you make using a common home lamp light bulb switch wired into the circuit for initial power up, kind of gives a gradual power up I believe (it's been some years), also possibly another benefit of detecting any circuit shorts. If you are interested I could dig it up I believe. Very cheap to make one. Once again your project is coming along great, it is somewhat envy inducing for me. Kind of you to share as well. You may also win the record for the longest thread.
kbp810 Posted May 15, 2011 Posted May 15, 2011 Indeed, 'tis coming along great! The silicon is a good idea for those orange drops; I once had a nasty vibration that I was pulling my hair out trying to track down, come to find out it was two orange drops clacking against each other! Hfan, that slow initial start/light bulb switch idea sounds interesting, so if you happen to come across it again I'd like to check it out; I wonder if perhaps it involved using a dimmer switch?
kbp810 Posted May 15, 2011 Posted May 15, 2011 Oh yes, and let's not forget your longest thread award H! It's all polished up and ready to go... just waiting on shipping quotes.
mooonpi Posted May 15, 2011 Posted May 15, 2011 google "light bulb limiter" and you'll finds some instructions for the device you speak of. I built one and have used it. It's a great idea. Actually helped trouble shoot some wiring without the fear of 'blowing sh...stuff up'. It's basically a poor man's variac...use it to control the amount of power going to your circuit from your wall outlet. To say the least it is coming out very well Howard. The neatness of your circuit layout is commendable. I was a field tech for many years and none of my work came close to being that pretty although mine wasn't a labor of love. When I add caps to a circuit in an amp I add a little silicon adhesive (GE bathroom silicon caulk in the states) under the caps as a remedy to vibration induced problems. You may have heard of this one..the only time I worked on a total refurb (my old Twin Reverb) I learned of a home made device you make using a common home lamp light bulb switch wired into the circuit for initial power up, kind of gives a gradual power up I believe (it's been some years), also possibly another benefit of detecting any circuit shorts. If you are interested I could dig it up I believe. Very cheap to make one. Once again your project is coming along great, it is somewhat envy inducing for me. Kind of you to share as well. You may also win the record for the longest thread.
H Posted May 15, 2011 Author Posted May 15, 2011 Oh yes, and let's not forget your longest thread award... I think mars_hall's 'Enough Said Music' thread has at least sixty more responses than this one. So far
H Posted May 15, 2011 Author Posted May 15, 2011 Howard, this is as good as, perhaps better than, any project thread I've seen on the HOC in the four years I've been here. The project itself and the documentation have been thorough, articulate, and as much a pleasure to follow as you seem to have had in doing it. What a terrific piece, in both concept and execution! Thanks for sharing this with us! My only problem has been with what a "numpty" this makes me feel like. Congratulations on a job very well (nearly) done! Hope it sounds fabulous! Thanks for the kind words, Rob, you have me blushing here
H Posted May 15, 2011 Author Posted May 15, 2011 To say the least it is coming out very well Howard. The neatness of your circuit layout is commendable. I was a field tech for many years and none of my work came close to being that pretty although mine wasn't a labor of love. When I add caps to a circuit in an amp I add a little silicon adhesive (GE bathroom silicon caulk in the states) under the caps as a remedy to vibration induced problems. You may have heard of this one..the only time I worked on a total refurb (my old Twin Reverb) I learned of a home made device you make using a common home lamp light bulb switch wired into the circuit for initial power up, kind of gives a gradual power up I believe (it's been some years), also possibly another benefit of detecting any circuit shorts. If you are interested I could dig it up I believe. Very cheap to make one. Once again your project is coming along great, it is somewhat envy inducing for me. Kind of you to share as well. You may also win the record for the longest thread. Thanks Pete I'm trying to build something I'd be happy to buy. So far, so good The light bulb gizmo looks interesting, I'll look into that. The longest thread still belongs to mars_hall's 'Enough Said Music', I'm afraid. Still, I'm not quite finished yet
Hfan Posted May 16, 2011 Posted May 16, 2011 Herre is a link for the light bulb limiter http://tubenewbie.com/light_bulb_current_limiter.html Yes it is a poor man's variac. Howard, forgot to mention, nice touch adding the h logo. If this amp sounds half as good as it looks you should be very happy.
H Posted May 19, 2011 Author Posted May 19, 2011 Well, another milestone reached today: the wiring for the electronics is complete! Some intermediate pics: This is it fully wired and tidied up: Now I need to buy some bits to make a light bulb limiter. I've made a capacitor discharge tool and on Saturday I'll be debugging the circuit - one arm behind my back
DetroitBlues Posted May 20, 2011 Posted May 20, 2011 Samamp also uses some kind of lightbulb device to cut the wattage on his amps. Steviesnacks.com demo'd one with the different settings. Overall, I thought it sounded really good.
Hfan Posted May 20, 2011 Posted May 20, 2011 Oh yes, and let's not forget your longest thread award H! It's all polished up and ready to go... just waiting on shipping quotes. Where is that picture from Brian? Or is it some kind of photo shop hocus pocus?
