Heritage HISTORY #3
FredZepp
The three founders of Heritage Guitars (Marv Lamb, J.P. Moats, and Jim Duerloo ) all hired-in Gibson within two years of each other ( 1956 - 58).
They all started in white wood sanding and they all progressed to senior management in the 1970's.
They did a vast variety of jobs, hands on, including sanding, carving, finishing, neck sanding, repairs , custom shop, pattern making, tooling, wood inspection, etc. ..
Marv Lamb:
" My father worked at Gibson. I was working at a bakery in Kalamazoo in 1956. He started in January and I got him to get me a job.
Dad started working in the lumber yard, that is where they cut the lumber in the "rough mill". " [ Marv's brother and sister-in-law would also eventually work at Gibson in Kalamazoo also ]
Going back to the 50's, where did you go to work after sanding?
" After about a year , or a year and a half, I went to work in the neck department. Making necks, belt sanding necks."
Was there a saw or something to carve the neck?
" It was done by hand. The necks came from the mill room in a rough shape. We would take them and glue the fingerboards on them, glue head veneers on them. Then I would take and shape that neck with s slack-belt sander. And we had a guy that would carve the heels; the heels were kind of square. He'd use a spindle carver; it was like an eight blade knife sticking out on a spindle. He would carve the heel and the flair. Then I would take and roll the neck on that slack-belt sander, and round the neck. Then sand it up. Then I'd go over to a spindle sander, which was basically like a spindle carver. Then I'd have a tube sander, and I'd sand it up some more."
Now you had quite a bit of control over the shape of the neck then?
" Absolutely. I hand shaped a lot of necks. ....."
" We had gauges to measure the thickness and we had radius gauges for the curvature of the neck- the roundness. There were certain gauges for certain necks, and certain fixtures for certain necks.
And as much hand work as we did on them, I promise you, they varied. But we got as close as we could, once you learned how to do a thing, you'd get them pretty consistent.'
" I was doing all that white wood work and neck work during that period 1956-59 ( on the first floor of the original building ) When I went out to the new area (the 1960 expansion ) I was still a 'line leader'. At that time, we hired a lot more people."
[ NOTE: Les Paul Standard 'Burst owners are well aware the the 1960 Les Paul Standards neck has a pronounced flat profile verses the rounder U-shaped neck of the 1959 'Burst. The neck machines were relocated in late 1959/ early 1960 at the same time the neck profiles changed. Neck profiles changed back to the U-shaped profile in 1963. ]
( Edited from Gibson Guitars: Ted McCarty's Golden Era )
Fred, great stuff. You never cease to amaze me with your historical information and perspective.
Thank you
rock and roll!
