How do they fit the maple cap on?
MartyGrass
i believe they glue the plank top onto the mahogany slab and then cut it out, carve it and route it...in that order....i think
It has to be done first because the outside mahogany is solid through the guitar. Some (non-Heritage) chamber through the mahogany then put a maple cap on the front and back.
That's why the H-137's are flat... They are the same slabs of mohagany which maple caps are glued on. That's why those are so thin compared to H-140's or H-150's...
Does any one of you happen to know the chambering pattern used on 150s?
Thanks
You are Correct Sir!! Thus saving the back of the player!!
Are the caps the same for the 150s and 140s but with different mahogany slabs?
It's adjustable just like a baseball cap.
