strap button on bigsby's
bolero
so I'm having issues with the strap button on a bigsby b7
the button is inside the hole where the bigsby surrounds the bottom part, the strap is BARELY holding on, I'm worried it'll fall off & the gtr will hit the ground
I'm thinking the solution is to use a longer screw, plus a couple small washers to elevate the button out where the strap can get a proper wrap around it
has anyone else dealt with this?
ps the gtr is a millenium hollowbody: is there a solid chunk of wood at the base, or is it hollow there? if it's hollow a longer screw probably isn't going to be a great solution
thx!
Hm... I can honestly say I have never had that issue with a Bigsby but I also had a different model Bigsby on a different brand guitar.
My immediate response would be to do just as you mentioned: longer screw with a stack of washers tall enough to push the button out where the strap can properly grip it.
The other option is the Grolsh washer trick. :D
This is an oldie but goodie, works like a charm, costs only the price of a bottle of Grolsh beer, your strap is essentially locked in place AND you have a bottle of Grolsh to finish. haha.
yeah, I have tried that before lol
however as-is, there is barely enough space to get the strap on, let alone a washer overtop
my standard operating procedure is to put a .10c steel washer overtop & leave it on there permanently...there is no way it will fall off
