So, you want a Heritage that doesn't make...
barrymclark
Assuming that is a guitar Heritage would reasonably make, what is it?
Mine:
Heritage H500
-17" lower bout
-25.5" scale
-3-3/8" rim depth
-no cutaway
-rosewood fretboard
-mahogany neck
-laminate maple back and sides.
-multiply bound body, fretboard and peghead
-single P90 in the neck position
-rosewood bridge
-split-block inlays on fretboard
-a honey toned translucent finish on the top/transfer black on back/sides/neck
Yours?
Triple P90 lefty 357, with triple binding all over, in triple AAA five piece neck, mother of pearl and abalone block inlays inlays, mega super duper inlaid headstock.
Have I missed anything ?
Bling to the max, that should do it.
Three is a good number
aren't they making 357's made to order though?
full-hollow prospect
Oh and semi hollow with custom triple bound f holes. :diablo_mini:
:icon_flower:
Hmm... hadn't given it much thought :rolleyes_mini:
HOC127
25 1/2" scale
Body - Ash
Top f-hole (ala tele thinline)
Neck - solid maple, set, 9.5 radius, med-jumbo frets
Headstock - standard 127 style.
Through body string feed to a compensated 3-barrel bridge.
Lollars - P90 soapbar neck, vintage T tele bridge
Switches - Volume, Tone, 3-way switch controls (in that order)
Rim plug
7 to 7.5lb weight target
Finish - cherry translucent
Pickguard - none
HOC127
25 1/2" scale
Body - Ash
Rim plug
Pickguard - none
Really ?
There seems to be lots of P90 love in this thread.
They already make it - H150CM amber top, maybe ribbon quilt, but, dare I say this, a different he------k!
Traditional hardware, top quality vintage style pup's, dark rosewood neck, perhaps no binding on the neck, prs style bound effect - after all,binding is just plastic.
HOC127
25 1/2" scale
Body - Ash
Rim plug
Pickguard - none
Might as well have them make two while they're at it. Altho' I'd want a more traditional pickguard and that new SD pickup swopping system. Or not.
Really ?
We have the Lord of P-90 tone right here as one of our members so the P-90 love is all around.
Heritage Stat Deluxe, or PRS-ish shaped variant
25.5" scale
Iced Tea-ish burst on a nice curly figured Maple top, placed on a Mahogany OR Basswood body
Les Paul/H-150/H-157 body thickness
Belly cut
Carved top
Split-block inlays on Ebony or dark Rosewood board
CC-Rider, standard-sized single coil, or splittable humbucking neck pickup
P90 or Tele-bridge-like Strat-sized middle pickup
Nice splittable slightly-hotter-than-vintage bridge pickup, with offset/"splatted" wound wire so it split to a ~6-to-8k rating, alternately some P90 equipped/incorporated variant
5-way switch OR 3-way toggle with Push/Pull on/off for the middle pickup
Three volumes and one tone, or two volumes and two tone where the middle shares the neck tone & volume, activated by switch or Push/Pull
Push/Pull OR Seymour Duncan Triple Shot (or similar setup) for coil splitting, out-of-phase, and in-a-series wiring options, just to have handy
Pigtail intonatable wraparound bridge OR Floyd Rose available
Bound body, neck, and headstock
Jackson 6-inline or Carvin/PRS-style 3x3 headstock
Chunky asymmetrical neck
Heel-less design and beveled edges for nice upper fret access
Or that, only set up like a Hamer Californian with a slanted-at-the-bottom 27-fret design, Floyd Rose, shark-fin inlays, single-coil neck pickup and hot bridge pickup.
Not that I put any thought into this or anything.
Classic Eagle with Single cutaway solid carved mahogany top, mahogany back, sides and neck with natural finish. Black binding on the body and "f" holes. 25 1/2” scale ebony fingerboard with mother of pearl dot inlays; 20 frets, radius 12", and nut width 1-11'16". Ebony bridge as well as an ebony pick guard with tone and volume control. Heritage #3 jazz floating pickup with black Grover individual machine heads. Black Heritage bail tailpiece and Strap/Jack that is in end of tailpiece. Rim Thickness - 3”, body Width - 18”, and body Length - 20 7/8”. :thumbsup:
I think you already have one. make it a two pup thinline and I'm in.
Neck-through Millennium DC with no f-holes and no internal chamber.
I like that idea! :icon_thumright:
I think a good place to start is here....
As awesome as it is, that is just a 157 with some bling. If it was a full hollow or something... that is starting to get where I am talking.
I mean a MODEL they don't make. I'll let the semihollow 357 pass... but JUST barely.
My H500 is based on the postwar ES300 that Danny Cedrone played.
The SG shape is down the right path.
The 127 is alright since they simply won't build it but they had before.
What about the double Florentine cut full hollow..
