Back binding on H-157's? Always? Sometimes?
pushover
It has been so long since I have seen one of these in person I can't say.  Send an e-mail to Heritage.
the 157 i used to have, had back binding...i believe it is a standard feature
that one has all the tell-tale signs of a 157....headstock inlays, blocks on the ebony board, wood P/G, tripple binding
The H-150 Limited Edition from back in the late 80s/early 90s had a scarfed (what Heritage calls a belly cut) body and a multi-ply bound top (but not back).  It had a curly maple, matching finish headstock veneer, though.  This looks like a cross between the H-157 and the H150LE.  It would be interesting to see the build sheet for it.  Either it's an H-157 with rear binding delete and addition of a scarf, or a H-150LE with a peghead mod and first-fret inlay.
Maybe we should call it an H-157 Limited Edition.  Too bad he doesn't have a shot of the serial number, it would be interesting to see if it had a limited run stamp on it.
The scarf/belly cut is what precludes the binding on the back.  It's a lot more difficult to inlay the binding due to the now complex shapes of the cut and even if done nicely it still looks bazzar because of the turns and twists in the binding.
I too, am quessing it is a 1-off.
Cheers, Cryoman
My wife's lefty H-157 has the scarf cut as well without binding.
This was a custom order.
he also claims 'neck-thru-body' - i think that is incorrect.
  • 2 weeks later...
