Loose Input Jack Help Needed For H535
Sprinter
What's the best way to tighten up the input jack on my H535? I've thought about holding the jack with a pair of snap ring pliers to keep it from spinning while tightening the nut.
Sprinter
That would work but you may want to tape around the jack on the body just to insure against that potential slip of the tool.
Thank you, to everyone for your help. I ordered the gripper and spanner wrench from StewMac.
Sprinter
hey what's the tool you need to use with the older recessed input jacks? I think stewmac sells them too
The tools arrived from StewMac today and worked perfectly!!! The spanner wrench will be handy for a lot of different jobs. if you do your own setups or guitar repair the gripper is a nice tool to have and everyone should have the spanner wrench.
Sprinter
The gripper tool comes with an attahment to do recessed input jacks.
Sprinter
If you don't want to spend a lot of money on something you may use only once, crow bar & a pipe wrench.
