Evans JE200
MartyGrass
I've played this amp for a few days now and love it.
It is dead silent in the absence of dimmer switches and nearbly electrical devices. The controls are easy to reach in the front, even the power switch, which is the master volume control.
It weighs about 30 lbs. There is a tilt support under it for better projection.
I have never heard any amp than can beat this one for clean tone. I've tried quite a few, too.
I suggest that you check one of these out if you get a chance. I never even heard of the company until about a week ago.
Don't know much about the company either. Solid state or tube? How much power? One twelve? Plywood or pressed wood construction? Have you hooked up an extension cabinet? How are low and high end responses?
