hokenfloken Posted December 20, 2011 Posted December 20, 2011 Greetings! I'm interested in buying a USB interface for my Mac. I run OS X Lion. There are tons of USB interfaces available, from cheap to expensive. I am not looking to spend a lot of money. In my mind, something like this shouldn't be really expensive. I just need something solid, reliable and macintosh-friendly. I will be using garage bands. Give me your suggestions. Thanks!
bolero Posted December 20, 2011 Posted December 20, 2011 I am using one of these with my macbook pro, works great with garage band Roland Octa-Capture http://www.roland.co...cts/en/UA-1010/ piece of cake to setup: install drivers, mac asks if you want to use it as an external soundcard, yes....plug headphones & instruments in & go!! the inputs will take 1/4" as well as XLR mic inputs
pegleg32 Posted December 20, 2011 Posted December 20, 2011 I am using one of these with my macbook pro, works great with garage band Roland Octa-Capture http://www.roland.co...cts/en/UA-1010/ piece of cake to setup: install drivers, mac asks if you want to use it as an external soundcard, yes....plug headphones & instruments in & go!! the inputs will take 1/4" as well as XLR mic inputs Looks interesting, just wondering if you have ever used it with a mic in (mic from amp) and a line out to a powered speaker. I'm having a hard time with lag. I want to copy my audio background into the software and than play it through the powered speaker as I record my amp.
bolero Posted December 20, 2011 Posted December 20, 2011 here's what I typically do: I have a stereo mic in front of an amp, fed into the roland's 1 & 2 inputs these go into the Mac via the USB garageband has multitracks playing back, that I've either recorded before or imported ( drums, bass, etc ) I record on top of that instead of a powered monitor I use headphones plugged into the roland....but monitors would be the same setup, run out of the roland's outs no lag problems yet?
bolero Posted December 20, 2011 Posted December 20, 2011 ps here is a pretty thorough review http://acapella.harmony-central.com/showthread.php?2746804-Roland-Octa-Capture-Interface-Now-with-Conclusions
Kmenne Posted December 20, 2011 Posted December 20, 2011 I will bring one to work today. M Audio Fast track. I have been using it with garage band for a long time!
pegleg32 Posted December 20, 2011 Posted December 20, 2011 here's what I typically do: I have a stereo mic in front of an amp, fed into the roland's 1 & 2 inputs these go into the Mac via the USB garageband has multitracks playing back, that I've either recorded before or imported ( drums, bass, etc ) I record on top of that instead of a powered monitor I use headphones plugged into the roland....but monitors would be the same setup, run out of the roland's outs no lag problems yet? Thanks Bolero, that sounds like it will work. I will give it a try.
bolero Posted December 20, 2011 Posted December 20, 2011 pegleg, what kind of computer & OS are you using? there are sampling rates you can set/adjust, depending on what your hardware is, this can have a big effect on lag also I know for a fact that Vista has a lot of audio problems, compared to a Mac or Windows 7
GuitArtMan Posted December 20, 2011 Posted December 20, 2011 Well I'm still running Snow Leopard on my iMac. When I asked the same question over at TGP about this time last year I got more recomenedations for the Apogee Duet than all other interfaces combined. Their DACs/ADCs and drivers are suposed to be superior to anything in it's price range.
pegleg32 Posted December 20, 2011 Posted December 20, 2011 pegleg, what kind of computer & OS are you using? there are sampling rates you can set/adjust, depending on what your hardware is, this can have a big effect on lag also I know for a fact that Vista has a lot of audio problems, compared to a Mac or Windows 7 I have a Dell PC running vista and an Apple Macbook Pro running OS 10.6.8. My interface is a Yamaha Audiogram 6 which I originally bot to run with the Dell - I was never very happy with it. And for whatever reason they never made a driver to run on the Mac. Recording has always been something that just drove me up a wall so I have ended up lately recording everything in one shot with either a hand held recorder or just doing a video. Someday I would actually like to mix and refine something.
