gjdbav89 Posted January 2, 2012 Posted January 2, 2012 Recently was having a problem with the neck volume cutting out when turned past 8. Just came out of nowhere. I purchased a new CTS 500k pot and had a local tech install but the problem persists so it's not the pot. He spent some time with it but couldn't find anything wrong with the wiring. Any suggestions? Thanks.
mars_hall Posted January 2, 2012 Posted January 2, 2012 If you have meter, put the guitar in neck position and measure the resistance (ohms) at the end of the guitar cord between the tip and shield. Rotate the knob and look for a large jump at 8. If it is smooth throughout the turn, it likely is not the guitar. What do you get? A pic of the control cavity would help.
gjdbav89 Posted January 2, 2012 Author Posted January 2, 2012 Thanks. He still has the guitar. I'll give that a try if I get it back from him without him figuring it out.
jmac Posted January 3, 2012 Posted January 3, 2012 I had the same problem. Changed the pot but still think something is wrong..
