Identification of a PAF pickup
PAG
Hi All, this pup was factory installed to my '03 Roy Clark model. Someone can help me to identify it?
Looks to be a Gibson Burstbucker Pro. I had a couple of them, looked just like that on back. Great sounding pickups.
Yep, I believe you are correct.
You should be able to find the output chart for Gibson pickups. That should help identify the exact pickup. Be sure the pickup you find only has the two wire braided humbucker. Some have a plastic or four conductor wiring....
Thanks it was a great idea! The pup is 8.9 Kohm and since none of the Gibson pups are identical I guess it's a Lindy Fralin PAF...
Due to tolerances, you will never get an exact match, only a range of values for all produced pups that center around the nominal value.
