DetroitBlues Posted January 16, 2012 Posted January 16, 2012 Straighten your tie... Cables, cables, cables... I now have four cables to monkey with and a daisy chain of power supplies.... So now, I need to straighten it all up and tie down the cables to keep them secure and neat. My list of things to do is create a pedal board that holds down the power supply and keeps the cables organized. From there, put together specific cables that are tied together that serve a purpose of connecting to the Send and Return of the effects loop as well as the wah pedal between the guitar and the input of the amp. Not to mention, I'm going to order the footswitch for the amp... Lots of cables, and what a rats nest it is today. My post title should read Straighten up your cables and tie it all down, but its more catchy this way.... More to come on this subject, first I need to place an order with Mr. Steiner for some more cables....
JeffB Posted January 16, 2012 Posted January 16, 2012 My boards a mess. But everytime I make custom leads, risers for stomps or tie anything down I swap out a stomp and have to start again. The only certainty of it is the size of the board itself.
barrymclark Posted January 16, 2012 Posted January 16, 2012 I've only had one pedal board. It just stayed neat. haha. So... I have nothing I can really add. I think the major reason it stayed so neat was that I had a Furman board. Same people that make the power conditioners. It really reduced the crap on the board by simply not having the wall-warts all over the place.
smurph1 Posted January 16, 2012 Posted January 16, 2012 I changed mine again already..The dyna comp is out, and I'm thinking another distortion is coming onboard next to the seasick green TS-9..LOL... fickle musicians..
Trouble Posted January 16, 2012 Posted January 16, 2012 On 1/16/2012 at 2:59 PM, DetroitBlues said: Straighten your tie... Cables, cables, cables... I now have four cables to monkey with and a daisy chain of power supplies.... So now, I need to straighten it all up and tie down the cables to keep them secure and neat. My list of things to do is create a pedal board that holds down the power supply and keeps the cables organized. From there, put together specific cables that are tied together that serve a purpose of connecting to the Send and Return of the effects loop as well as the wah pedal between the guitar and the input of the amp. Not to mention, I'm going to order the footswitch for the amp... Lots of cables, and what a rats nest it is today. My post title should read Straighten up your cables and tie it all down, but its more catchy this way.... More to come on this subject, first I need to place an order with Mr. Steiner for some more cables....
Trouble Posted January 17, 2012 Posted January 17, 2012 Detroit I'm not sure what your running now but if things go the way I expect in the next couple months I may just send you my Direct Drive and let you try it out it's seriously sweet I think youd like it.
Steiner Posted January 17, 2012 Posted January 17, 2012 On 1/16/2012 at 2:59 PM, DetroitBlues said: Straighten your tie... Cables, cables, cables... I now have four cables to monkey with and a daisy chain of power supplies.... So now, I need to straighten it all up and tie down the cables to keep them secure and neat. My list of things to do is create a pedal board that holds down the power supply and keeps the cables organized. From there, put together specific cables that are tied together that serve a purpose of connecting to the Send and Return of the effects loop as well as the wah pedal between the guitar and the input of the amp. Not to mention, I'm going to order the footswitch for the amp... Lots of cables, and what a rats nest it is today. My post title should read Straighten up your cables and tie it all down, but its more catchy this way.... More to come on this subject, first I need to place an order with Mr. Steiner for some more cables.... I've heard that those are some good cables! Your audience demands pictures; we better get this right!
DetroitBlues Posted January 17, 2012 Author Posted January 17, 2012 On 1/16/2012 at 10:25 PM, Slammer said: You need a Boss BCB 60. Had one, hated it.... it lies flat, no tilt, and takes up more space then necessary. I did like it because I could put my TU-15 on the top and run the pedals below.... Costs way too much for so little, even used.
DetroitBlues Posted January 17, 2012 Author Posted January 17, 2012 On 1/17/2012 at 1:30 AM, Steiner said: I've heard that those are some good cables! Your audience demands pictures; we better get this right! Pics will come tonight if I remember.....
Guest HRB853370 Posted January 17, 2012 Posted January 17, 2012 On 1/17/2012 at 4:11 PM, DetroitBlues said: Had one, hated it.... it lies flat, no tilt, and takes up more space then necessary. I did like it because I could put my TU-15 on the top and run the pedals below.... Costs way too much for so little, even used. You are kidding right? The pedals are so close together, I see it as a very space efficient unit. Of course, if you don't need or want 6 boxes, there is always the BCB30. I got mine used for around $60 on ebay. I don't think they are expensive at all, considering they give you the built in power supply, and the deluxe cables with gold plated connectors. The downside is if you don't use Boss pedals you have to cut the foam. BTW, if you quit leaning backwards when you play, you won't need tilt!
DetroitBlues Posted January 17, 2012 Author Posted January 17, 2012 Had one of those too. I thought the boxes were too cumbersome. Its great for transporting, but I don't like how the held the cables in place and the BCB30 doesn't have a built in power supply....
tbonesullivan Posted January 18, 2012 Posted January 18, 2012 I would just get a piece of ply wood, smooth the edges, put down a bunch of velcro with an edge around it to hold the edges down, and go to town. You could get a pedal switcher like Brent has, which basically is a giant pedal with 6+ effects loops, one for each pedal. This way you can switch pedals in and out at your leasure. I generally don't run stompboxes through the loop, as they often don't deal with with the line level signal. I have a rack mounted module that I use for all of my modulation effects: reverb, chorus, flange, rotary speaker, delay, etc. It has a 2 button footswitch that can be used to turn off the individual effects.
