heritagefan7 Posted January 18, 2012 Posted January 18, 2012 Is the VIP system intended to serve the same purpose (tonally) as a P-rail pick up?
brentrocks Posted January 18, 2012 Posted January 18, 2012 not exactly.... the VIP is a 3-way mini toggle that is hooked up to each of the HRWs...and this is how they work: Center position: regular humbucker Up: Coil tap Down: Out of phase i could have the positions mixed up? but in a nutshell, thats what is does.
skydog52 Posted January 18, 2012 Posted January 18, 2012 From the website: INSTRUCTIONS FOR THE D-VIP (DOUBLE VAR-I-PHASE CONTROLS) Please Note : The D-VIP controls work best with our new HRW pickups. Each HRW pickup, has four lead out wires, plus ground, plus complete full length wire shielding for all 5 wires. ( Right handed player ) Sitting in the playing position. Lower left = master volume control, for both pickups Lower right = master tone control , both pickups. Upper left VIP control knob. 10 = in phase, for fingerboard pickup. 0 = out of phase, for fingerboard pickup. ( mini switch down) Please note that when on "O", there is little volume, because the bass and mid-range have been phased out. Upper right VIP control knob. 10 = in phase, for bridge pickup. 0 = out of phase, for bridge pickup. ( mini switch down) Please note that when on "O", there is little volume, because the bass and mid-range have been phased out. Two Mini Switches: ( 3-way ) The one on the left = Fingerboard Pickup, The one on the right = Bridge pickup. Position: 1 ( Down) = VIP ( VAR-I-Phase) The only time the VIP works, is when the mini-switch is down, for that pickup. Position : 2 - ( Middle) = FULL, (Both Coils), ( normal ) Position : 3 - ( UP ) = COIL TAP, ( single coil) Note: Main toggle switch, works like normal. UP: Front pickup. Middle: Both pickups. Down: Bridge pickup.
Gitfiddler Posted January 18, 2012 Posted January 18, 2012 On 1/18/2012 at 10:31 PM, skydog52 said: From the website: INSTRUCTIONS FOR THE D-VIP (DOUBLE VAR-I-PHASE CONTROLS) Please Note : The D-VIP controls work best with our new HRW pickups. Each HRW pickup, has four lead out wires, plus ground, plus complete full length wire shielding for all 5 wires. ( Right handed player ) Sitting in the playing position. Lower left = master volume control, for both pickups Lower right = master tone control , both pickups. Upper left VIP control knob. 10 = in phase, for fingerboard pickup. 0 = out of phase, for fingerboard pickup. ( mini switch down) Please note that when on "O", there is little volume, because the bass and mid-range have been phased out. Upper right VIP control knob. 10 = in phase, for bridge pickup. 0 = out of phase, for bridge pickup. ( mini switch down) Please note that when on "O", there is little volume, because the bass and mid-range have been phased out. Two Mini Switches: ( 3-way ) The one on the left = Fingerboard Pickup, The one on the right = Bridge pickup. Position: 1 ( Down) = VIP ( VAR-I-Phase) The only time the VIP works, is when the mini-switch is down, for that pickup. Position : 2 - ( Middle) = FULL, (Both Coils), ( normal ) Position : 3 - ( UP ) = COIL TAP, ( single coil) Note: Main toggle switch, works like normal. UP: Front pickup. Middle: Both pickups. Down: Bridge pickup. That is DEFINITELY Rendall-speak! Ha-ha!
MartyGrass Posted January 18, 2012 Posted January 18, 2012 Once you play around with the switches it becomes second nature. It's different from P-Rails in that there are no "P"s or rails in them. Otherwise the switches are very similar in concept. The D-VIP system also lets you adjust how much out of phase you want to sound. I haven't seen P-Rails set up that way.
