DetroitBlues Posted February 16, 2012 Posted February 16, 2012 Ok, loving my Deltablues. So tonight I had my Epi Dot plugged into the wah>od>input. While the amp was on, I unplugged the OD pedal, then unplugged the power supply to the wah and its input/output cables. I finished adjusting the pot on the Wah, plugged the input/ouputs back up and as soon as I connected the power supply, there was a pop. Now there is NOTHING. No sound at all on either channel. Did I blow a preamp tube? What was odd is I didn't connect the OD pedal yet. So there was no guitar input into the amp.... What the heck did I do?????
DetroitBlues Posted February 16, 2012 Author Posted February 16, 2012 On a whim, I unplugged the effects loop cables, and the sound restored. I wonder if I caused a power spike in the effects loop. Wonder if the loop is tube driven????
DetroitBlues Posted February 16, 2012 Author Posted February 16, 2012 No pots. Right now, KBP and I are thinking one of two things happened when I connected that power supply. I either blew an internal fuse or circuit in the DeltaBlues or I fried my Boss DD3 Delay....
DetroitBlues Posted February 16, 2012 Author Posted February 16, 2012 Problem has been solved. Used a patch cable in the effects loop and the amp worked fine. Plugged the delay after the OD pedal, and nothing. Put the OD pedal back to the input cable, amp is fine. Put the effects loop cables on the flanger, all good. So some how, in the grand scheme of things, my Visual Sound One Spot blew up my Boss DD3 Digital Delay.... Damn wall warts!
Joe Posted February 16, 2012 Posted February 16, 2012 Just for reference, are you using some effects in line and others in the effects loop? I', tinkering with my set-up and want to compare notes.
DetroitBlues Posted February 17, 2012 Author Posted February 17, 2012 Yes, I put my wah and od pedal in front of the preamp. I put modulated effects such as delay and flanger between the preamp and power amp section using the effects loop. This is only necessary if you are using the natural od of the preamp section. Such as amps with gain and master volume settings. For Fender clean type amps, its not necessary since the overdrive is coming from the pedals and not the preamp.
Joe Posted February 17, 2012 Posted February 17, 2012 Yes, I put my wah and od pedal in front of the preamp. I put modulated effects such as delay and flanger between the preamp and power amp section using the effects loop. This is only necessary if you are using the natural od of the preamp section. Such as amps with gain and master volume settings. For Fender clean type amps, its not necessary since the overdrive is coming from the pedals and not the preamp. Thanks Detroit. That's pretty much my set-up minus the wah.
Guest HRB853370 Posted February 17, 2012 Posted February 17, 2012 I had no sound out of mine the other day, with all the fx stuff connected. I was like, WTF. Then, I ran the guitar cable directly into the Delta, and I had sound. Ok, WTF again. So then I reconnected the output from my FX board back into the amp and reconnected my guitar cable into the first input of my FX chain and had sound. I still do not know what happened.
DetroitBlues Posted February 17, 2012 Author Posted February 17, 2012 Apparently, when I plugged in the wah pedal it was engaged and caused a powerspike down to the DD3 since its a buffered bypass. Wouldn't of happened if I had an isolated power supply. Now I'm in the market for a new delay. Perhaps I'll look into an analog delay now.
smokedtires Posted February 17, 2012 Posted February 17, 2012 Glad to hear you're back up and running
DetroitBlues Posted February 17, 2012 Author Posted February 17, 2012 Except for my delay. Such a useful and fun effect....
schundog Posted February 17, 2012 Posted February 17, 2012 Yeah, the Delay can be addicting. I'll bet you wish it was your Flanger that took a crap instead, haha.
DetroitBlues Posted February 17, 2012 Author Posted February 17, 2012 No doubt. Flanger wasn't even in the chain at the time.....
bolero Posted February 17, 2012 Posted February 17, 2012 woah, that's weird, I never figured a signal spike would kill a delay pedal? was the DD3 battery powered? or plugged into a walwart? too bad if it's dead, Boss makes good delays....RIP
Guest HRB853370 Posted February 17, 2012 Posted February 17, 2012 Except for my delay. Such a useful and fun effect.... What would you use delay for? I dont have one..... You have reverb right?
schundog Posted February 17, 2012 Posted February 17, 2012 What would you use delay for? I dont have one..... You have reverb right? Reverb is no substitute for Delay. Delay. Delay. When I use mine, I usually use my Digital Delay set at a very short delay setting, giving a slapback echo effect. This video is just one of probably thousands on YouTube demonstrating delay use; I think to use Delay PROPERLY, one needs to be able to walk and chew gum at the same time, so that leaves me out....
DetroitBlues Posted February 17, 2012 Author Posted February 17, 2012 woah, that's weird, I never figured a signal spike would kill a delay pedal? was the DD3 battery powered? or plugged into a walwart? too bad if it's dead, Boss makes good delays....RIP I was using a Boss power supply with their daisy chain for it. It was plugged in, along with my Digitech Bad Monkey. The sudden voltage from the Wah since it was engaged killed it.
koula901 Posted February 17, 2012 Posted February 17, 2012 Sorry to hear you were having such trouble with your equipment and your DD3 got burnt out. Maybe you'll find another one? Maybe it's time to get a power supply.
DetroitBlues Posted February 17, 2012 Author Posted February 17, 2012 What would you use delay for? I dont have one..... You have reverb right? I have reverb and I use it alot, but to give me a tone like Bonamassa, I use a delay.
Guest HRB853370 Posted February 17, 2012 Posted February 17, 2012 I have reverb and I use it alot, but to give me a tone like Bonamassa, I use a delay. That doesnt tell me much. When I listen to Bonamassa, what tunes does he use delay on? I dont hear it.
tbonesullivan Posted February 17, 2012 Posted February 17, 2012 that's odd. there really shouldn't be a way for the wah to output enough signal to fry the delay pedal. at most it will just overdrive it and make it clip like mad. Sounds like something is odd. Also, effects loops often are wired so that if you plug something into them, the internal link between the pre and power amp sections is disconnected. If the jack is worn or dirty, it can mistakenly think that a wire is plugged in, and ends up disconnecting the preamp from the power amp.
schundog Posted February 17, 2012 Posted February 17, 2012 Think The Edge in U2 on "Where The Streets Have No Name," or a lot of David Gilmours stuff. Delay adds a lot to the signal IMHO. YouTube delay and get back to us in a week, haha. That doesnt tell me much. When I listen to Bonamassa, what tunes does he use delay on? I dont hear it.
schundog Posted February 17, 2012 Posted February 17, 2012 Sellout...haha I have reverb and I use it alot, but to give me a tone like Bonamassa, I use a delay.
