9 hours of labor-and a safe delivery!
I agree, some amps just sound too sterile being so clean...
Thats why I like my DRRI, it plays cleanly until you get it cranked to around 7, before saturation starts. I won't need any fx boxes with the Tweed.
  • Replies 68
  • Created
  • Last Reply
so, do ya love it more than your blackstar ht 5?
Reverb is a must for me... The Tweed takes pedals really, really well.
Congrat Wil, like the colors you picked too. Dibs, that would match my Reverb deluxe perfectly.
I never really liked that Blackstar to begin with. So the answer is an overwhelming yes.
Sure dibs it is. Is your Reverb Deluxe a KBP amp?
Yepper, hence the reversed moniker. When Brian told me to pick a grill cloth and cabinet covering from Mojo, I went with the colors on yours, Oxblood grill and Tweed cabinet correct?
here is a pic from PSP, prior to its trial by fire.
That amp got a ton of play at PSP. So many people were plugged into it. It held its own and sounded great!
Tell us about the two channels, Slammer. Can u set one to clean and the other dirty?
Channel one is the overdriven one, and channel two is the cleaner one, or it takes more to saturate the amp. There is no switch so you have to unplug from one channel on the amp and plug in the other one. No big deal!
Now I remember. You are Pete, right?
or you could get a couple cables & a simple A/B switch...can be pretty neat with using guitar vol to switch between chunky cleanish rhythms and singing solo stuff...
Send me a link RJ, if you know of any good ones.
I don't see a standby switch unless the switch marked ground is the standby switch.
Yeah, the ground labeled switch is wired as a standby. The need/use for the "ground" switch is obsolete now... some of the re-production chassi have it labeled as standby, but others still have it marked as ground like the original.
Hope to see my KBP tommorrow, congrats Slammer!
Wow, that was a fast build Trouble!
Sounds like you need an A/B Switch. Or even cooler if you had an A/B/Y! You could use either channel or both at the same time!
Simply WOW! Beautiful. I hope you break it in before PSP.
Hey... I just noticed that I missed this thread... congrats on the amp.
I love the combination of chickenheads, tweed, and that leather handle.... that adds up to a good time with a warm amp.
Yes i do DB, and a couple people recommended different brands. Sweetwater sells a Morley for $55. What is the difference between AB and ABY?
Thank you Bulldog, she even sounds better than she look! Yes, I plan to bring it to PSP4!
Thanks Fredzep, man these are everything they are supposed to be!! Now if I only was able to keep one, this one would be it!
