MY KBP AMP!
knopfler74
So, KBP will be starting in on my amp build this week. I wanted to start a thread to share information on it, revel in the glory of having a new amp, and generally enjoy the process. I guess I'll start with a description of the build.
I asked him for a 15-20 watt amp that wanted to "live" on a edge of breakup. Sort of an indy rock dudes dream. British voiced. Enough clean to not only do OD, but enough gain to get me into crunch and beyond if needed.
Here's what KBP came up with
15 (or so) watt amp with a Master volume and volume. Treble and Bass controls.
The amp will run on EL84 tubes, but special ones....Russian mil spec tubes often referred to as 7189's. Apparently they can withstand much higher plate voltages, which is cool. KBP will also be using beefed up transformers in order to give me a little more headroom...if I remember correctly.
The design is very similar to a matchless lightning.
I'm still looking for names for it, so if anyone has any brilliant ideas, this might be the place to share them....
anyway...(best jersey voice) - talk amongst yourselves....
I'm off to work, in order to uh, 'mold America's youth' or something like that....
Today: more on ancient ROME!
  • Replies 50
  • Created
  • Last Reply
ha, the KBP syndrome is catching...sounds like a great amp build!!
how about " Henry VIII " ?
I am Henry the Eighth, I am, I am...
I have decided I want a KBP amp. Time to start saving up.
Congratulations on the amp; It sounds very cool, and I can assure you Brian does a great job; I love my Tweed Deluxe!
I think you should convince your school principal to let you show the Starz Network series "Spartacus" in class, so that they can get their History lesson AND Sex Education all in one sitting, haha. If you haven't seen it, "Spartacus" is a GREAT show!
http://www.starz.com/originals/spartacus
That's a design is similar to what he was going to do for me once. The Matchless amp is basically a hot rodded AC15 amp. It should be great when its all said and done! Congrats!
http://www.starz.com...inals/spartacus
I love that show! I have not seen this season's epipsodes, but the first season and the prequel mini-series was awesome!
The Party's AMP (and go with a red color scheme).
or some other russian related name/colors in honor of the special tube
Chernobyl (because it's so hot, it's nuclear!)
In my head I picture it with a plasticy chasis that is slightly melted for cosmetics...
If you MUST name it, I would just go with Knopfler!
Winston - as it is British voiced.
or
Stentorian (look it up) - a play on the Latin origin of Vox and its meaning in Latin.
If you want it to live on the edge of breakup, call it fault line.
So if KBP makes a Trojan horse, does that make KBP the Trojan Man?
why...I do believe it does.
I kind of agree with Mavguy, it will tell you it's name after a while if it needs one.
Dogs are that way too. Take mine, for instance: Cassie & Duffy aka Nitwit & Nutless
