knopfler74 Posted April 5, 2012 Posted April 5, 2012 My KBP amp will be here tomorrow, so tonight I'm messing around with Guitar Rig 4 in my Presonus Studio One v2 software. I've created two tones here...for your listening, uh...critique? I chose the introduction to the Goo Goo Dolls song "Slide" for this little comparison Here's what the two tones are Example 1 on the track AC30 amp model with matching cab Pedal style compressor in the emulation as well. MD 421 mic model from guitar rig used as well Slight dead air time between examples Example 2 on the track Fender Twin Reverb amp model with matching cab Pedal Style compressor inthe emulation (same settings as the AC30 example) MD 421 mic model from guitar rig used as well (set in same "virtual spot" as the AC30 example) No master buss or master track compression, EQ, or other wizardry used on the recording. Guitar is my Heritage 157 with Dimarzio 36th Anniversary pickups - Bridge pickup only for these examples. So, opinions, thoughts, rants, Axe FX is better? (Yeah, I know it is, so we can probably skip that ) Thanks Guys/Gals/Guitar nerds Which do you like more? Which sounds better to your ears and why? THANKS, you guys rock, as always. I really love this forum because the discussions you all usually get into are, for the most part, intelligent, respectful, and interesting! Matt SLIDE INTRO BRIT_USA.mp3
knopfler74 Posted April 5, 2012 Author Posted April 5, 2012 Note: I obviously rushed on the second example. Not sure why I was in such a hurry for that take...DOAH!!! Oh, and I played it without the capo or alternate tuning Rzeznik uses most of the time. I've watched him personally play it both ways, and in the key I did it here....when his voice was tired at a show WAAAAY back in the day
yoslate Posted April 5, 2012 Posted April 5, 2012 What skydog said. First, a little "rounder," more warm, fuller representation of the spectrum. Were I playing the rigs, number 1 would get the nod!
kbp810 Posted April 6, 2012 Posted April 6, 2012 #1 for me as well; but either way, some nice playing and sounds like a good quality recording
Kuz Posted April 6, 2012 Posted April 6, 2012 I, like others REALLY liked #1. #2 was too thin for me. As for is the Axe-Fx better...... well on those tones, maybe the same. But I would say I have 78 more amps that we can compare.... ha, ha. IT'S ALL GOOD IF IT SOUNDS GOOD!!!! THAT'S THE BOTTOM LINE!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DetroitBlues Posted April 6, 2012 Posted April 6, 2012 I'll disagree with the 2nd sounding thin, it just has less volume and less gain. Just more clean. For a live band situation, it would probably sound better. The actual song has a cleaner sounding guitar, much like recording two.
TalismanRich Posted April 6, 2012 Posted April 6, 2012 Of the two, I think that #2 would work better in a mix... It seemed like it was a little better balanced when I brought the volume up to the level of the first. There was a bit of peakiness for me on the first clip. I was listening through my headphones, it might play out a bit differently through monitors.
H Posted April 6, 2012 Posted April 6, 2012 I'm a Guitar Rig 4 user too:) It's a great tool for the recording process. I'd like to hear a revised number two with the guitar's tone rolled off a bit and a revised number one with the mids dialled out a fair bit. Thanks for the clips - nice work
JeffB Posted April 6, 2012 Posted April 6, 2012 Both sounded good. Good work. Would like to hear each in a mix of drums , bass etc to see which sounded better.
knopfler74 Posted April 6, 2012 Author Posted April 6, 2012 These are ALL outstanding points, and because the weekend is coming up, maybe I can expand this little exercise and add drums and some bass. Kuz, - SOOOOO jealous! You're right, you do have 78 other amps to play with! nice....
bolero Posted April 6, 2012 Posted April 6, 2012 I like the first one, not sure if because it's a bit louder or just more low end EQ but I bet either would work fine with drums/bass mixed in
