a peek at whats in the lab...
"Stay away from the black acid..... we have heard of better trips from the blue acid"
How did you swing board? If you made it yourself explain how you did the pic please. Nice and tidy very cool!
I bought the board empty (just turrets) then drew a picture on it with permanent ink. I'm just now getting the parts in place and ready for solder.
That's pretty freakin' cool, Lance. So if I'm remembering my Fender nomenclature correctly, a 50's Champ-type circuit? I can't wait to see the final product.
Yes, the circuit is champ type. Kbp helped me tweak the plans so I can swap out the 6v6 for a 6l6 or if I so choose an el34.
I wanted something low watt and this will be able to go from about 2 watts with an el84 (yellow jacket required) to about 12 watts with a 6v6 or el34.
So far it has been super easy with the exception of a little trouble distinguishing what color some of the bands on the resistors are. Old man trifocal eyes don't help.
it's going to be quite 5f1ish... but with just a little extra...
That looks like an addition to your electrocution device collection. Make sure that you learn to bleed the caps once you start plugging her in. You wouldn't want that beard to start smoking.
Nice addition; she's a cutie!
Ha! Very cool, Lance. A fun project.
Make sure you are sipping No Name's Tsar vodka while undergoing this project.
Man that is seriously cool, I never would have thought of personalizing the turret board itself like that but I like it. Since your talking about resistors, it seems like I was told or read somwhere that they are directional, or only work one way. Is that true and if so how do you tell which way is in and which way is out?
Resistors are not directional
Diodes and electrolytic capacitors that are often found in amp circuits have to go the right way though ;)
  • 3 weeks later...
Its been a couple weeks... what's the latest and greatest? Does it live?
The board is loaded and all soldered up. the head cab is in the mock up stage. The only thing I'm waiting on is the chassis. As of today still on back order. The cab is going to be quite modern.... Ha,ha,ha!
