Bridge mounting on archtops
What is the purpose of Heritage mounting the bridge on a piece of rosewood as in the Golden Eagle and the 575, versus the bridge mounted directly on the top as in the 550? Is it purely aesthetic or is there a tonal or functionality reason?
They (the bridge) are quite a bit further up on some archtops, if you mounted them direct on the top they would never reach. This also allows mounting w/o drilling holes, and spans the parallel braces for support.
I notice that the rosewood bridges are used on carved top guitars. I would assume that it has to do with the acoustic properties of the guitars.
+1 There is no need for a support block under the top to screw the bridge in with a baseplate bridge. The acoustic nature of the guitar is better preserved.
