ghumba Posted June 16, 2012 Posted June 16, 2012 Does Heritage build with scarf neck joints? Just curious, given the number of broken Gibson headstocks I've seen.
FredZepp Posted June 16, 2012 Posted June 16, 2012 Does Heritage build with scarf neck joints? Just curious, given the number of broken Gibson headstocks I've seen. Nope... no scarf neck joints on a Heritage..
Blunote Posted June 17, 2012 Posted June 17, 2012 This. I like it. Very SRV-ish. You need one of those DB for when you play that new Strat with the Texas Specials in it.
FredZepp Posted June 17, 2012 Posted June 17, 2012 A scarf joint can be a way of attaching a headstock ( Taylor does this) or it can be done farther down the neck ( you'll see this on some imported guitars)
DavesNotHere Posted June 17, 2012 Posted June 17, 2012 While I can't speak to the scarfed neck joint, I do know they did at least one scarfed headstock. It's difficult to capture (at least for me) with a camera, but in person it is quite obvious that the headstock on my Parsons Street is a three piece scarf.
FredZepp Posted June 17, 2012 Posted June 17, 2012 If you are talking about the wings laminated onto the sides, I don't believe that is called a scarfed joint. You'll see 150's and Les Pauls with that and they are stilled called a one piece neck.
DavesNotHere Posted June 17, 2012 Posted June 17, 2012 Yes, that's what I was talking about Fred, I didn't realize that was common practice. I've only been playing around with guitars for about a year and a half, I still have much to learn Obi Wan. The neck is definetly a one piece.
FredZepp Posted June 17, 2012 Posted June 17, 2012 Yes, that's what I was talking about Fred, I didn't realize that was common practice. I've only been playing around with guitars for about a year and a half, I still have much to learn Obi Wan. The neck is definetly a one piece. Beautiful pic of that headstock.... suitable for framing even. That guitar was a nice grab.
DetroitBlues Posted June 17, 2012 Posted June 17, 2012 A scarf joint can be a way of attaching a headstock ( Taylor does this) or it can be done farther down the neck ( you'll see this on some imported guitars) Ah, I think my epi dot is like that.
DetroitBlues Posted June 17, 2012 Posted June 17, 2012 If you are talking about the wings laminated onto the sides, I don't believe that is called a scarfed joint. You'll see 150's and Les Pauls with that and they are stilled called a one piece neck. The Gibson Melody Maker headstock is a normal headstock with out the wings.
TalismanRich Posted June 18, 2012 Posted June 18, 2012 My Dearmond and Dean have the scarf joint, my Taylor is one of the older ones with the finger jointed headstock. They have since moved to a scarf joint because of aesthetics. I think you will find that the majority of Asian guitars use a scarf joint for the headstock. Its probably quicker to build and more efficient in the use of the wood.
DetroitBlues Posted June 18, 2012 Posted June 18, 2012 My Dearmond and Dean have the scarf joint, my Taylor is one of the older ones with the finger jointed headstock. They have since moved to a scarf joint because of aesthetics. I think you will find that the majority of Asian guitars use a scarf joint for the headstock. Its probably quicker to build and more efficient in the use of the wood. ... And dare I say, more durable? Less prone to headstock breaks?
FredZepp Posted June 18, 2012 Posted June 18, 2012 Its probably quicker to build and more efficient in the use of the wood. Oh yeah... the ability to use shorter pieces of wood is a major plus for them .
Trouble Posted June 19, 2012 Posted June 19, 2012 My Dearmond and Dean have the scarf joint, my Taylor is one of the older ones with the finger jointed headstock. They have since moved to a scarf joint because of aesthetics. I think you will find that the majority of Asian guitars use a scarf joint for the headstock. Its probably quicker to build and more efficient in the use of the wood. In reference to your Taylor, I have one with the finger jointed headstock too, I don't know for sure but I bet it's stronger than a traditional scarf joint.
