Volume swells using tremolo effect
I stumbled upon a really cool effect a few minutes ago. I was playing a 150 through my Delta Blues, with the tremolo activated, intensity at about 6 and the speed on 2. I found that if I picked very lightly in synch with the tremolo speed, it sounded almost exactly like volume swells, creating a very cool violin like simulation. When I used an even lighter attack on the wound E and A strings, it sounded like a bow sliding across the strings!!
Cool.
While it's possible to do volume swells on a H150, it's not nearly as easy as on a Strat.
Do you mean using the actual volume pot Mark? Seems to me the volume control on a Strat is ideally positioned for the pinky finger to do swells. Jeff Beck is a master at it!
Cool.
it's possible if your pinky is 1/2 ft long
Will, could you record what you did? I am really curious to hear it!
Yeah, let me do that in the next few days Gio.
That's actually why I didn't like that circuit on the Delta Blues. It changes volume not pitch like the Reverb Deluxe. That's really cool that you can master that effect like that. Very difficult to keep the timing just right.
Drummer DB, drummer!
