mggns Posted July 24, 2012 Posted July 24, 2012 As I mentioned in the thread below, I just picked up an H555 and am loving it. I have a question on the sticker on the inside though. Pic is attached. It has the model as H555, as expected. It says "OSB" which I believe is for the "Old Style Burst" finish. It says "HRW PU" which I believe is for the original HRW's that were in it. The question is about the marking just under the model line. I think it says "T1110" and then there is a squiggly that looks like a "3." Does that have something to do with the neck, or some other feature? Let me know what you think! Thanks!
skydog52 Posted July 24, 2012 Posted July 24, 2012 As I mentioned in the thread below, I just picked up an H555 and am loving it. I have a question on the sticker on the inside though. Pic is attached. It has the model as H555, as expected. It says "OSB" which I believe is for the "Old Style Burst" finish. It says "HRW PU" which I believe is for the original HRW's that were in it. The question is about the marking just under the model line. I think it says "T1110" and then there is a squiggly that looks like a "3." Does that have something to do with the neck, or some other feature? Let me know what you think! Thanks! Serial no? Does it match up with the back of headstock?
mggns Posted July 24, 2012 Author Posted July 24, 2012 You are a genius. It is in fact the serial number, and it does match. Can't believe I didn't realize that. I would like to say this will be the last stupid question I will ever ask, but if history is any indicator, I'm sure it will not. Thanks for the help!
