HRW install and toggle switch porn
MartyGrass
I swapped out the 59s for HRWs on my H157. A Heritage affiliate luthier, Pete Moreno did the work.
I asked him to find a HRW toggle switch cap if he could. Well, he couldn't, so he made one.
He drilled out the top of a black cap and super glued a white fret marker in the hole. It looks fine.
It turns out this is how Ren Wall did these at Heritage. I did not know this.
The HRWs seem okay. The neck has that subtle chiminess. The bridge pup is a little mellower, maybe because it's a bit lower. I need to use them a little bit to figure them out.
P1010002-1.jpg?t=1349818337p1010003-1.jpg?t=1349818342P1010001-2.jpg?t=1349818370p1010004-1.jpg?t=1349818343p1010005-1.jpg?t=1349818346
Thanks Mark, I never knew that was how Heritage made the HRW toggle switch.
that looks great!!
I sometimes wonder if I should have ordered a 157 with a finish that shows off the wood more....your 157 is gorgeous
