602a Posted December 9, 2012 Posted December 9, 2012 Got the new 535 in last week and she has developed a Buzz on the A string baddddd. Weird thing is that's the only string. First does Heritage use "Bone Nut's" or could it just be cut too deep? Inquiring mind needs to know!
DetroitBlues Posted December 9, 2012 Posted December 9, 2012 Could be cut too low. Could be the string or the saddle is cut wrong... Have it checked out. If you barely had it a week, the shop should look into it free...
Blunote Posted December 9, 2012 Posted December 9, 2012 Could be the nut, or I suspect the neck might be too flat of back-bowed. And, while it's uncommon, sometimes frets raise up a little and need to be tapped back into their slots. I took delivery of a 535 a few weeks ago and it had a buzz on the D string. A couple of days after I re-tensioned the strings, the neck had a chance to stabilize and the buzz disappeared. Even so, the D slot was cut deeper than the others and the neck was a bit flat so I took it to my luthier for a set up. He filled and re-cut the slot and adjusted the neck and action . I also had him level and crown the frets. Guitar plays fine and no buzz. It seems usual for the necks to require adjustment when season's change. I guess if I have any complaint about Heritage, it is that most of my guitars have had poorly cut nuts. One string is invariably lower than the others and it fees awkward when playing at the first or second fret. Fortunately, it's an easy fix. BTW -Heritage uses bone nuts.
mark555 Posted December 9, 2012 Posted December 9, 2012 recently had a tusq nut installed on my 555, it is superb.
MartyGrass Posted December 9, 2012 Posted December 9, 2012 This is the first I've heard that Heritage uses bone nuts. Mine haven't been. It is common to need the nut and frets filed on a new Heritage if you want to get the best out of your guitar.
yoslate Posted December 9, 2012 Posted December 9, 2012 Where? Everywhere, fret x and above, only two or three frets...? Could be the nut (The groove shouldn't be all that deep; most of the string should appear up and out of the groove), saddle, string, or ,as Bluenote suggests, one fret up, out of the slot.... Is the "A" tuner snug (the key, the retaining nut)?
GuitArtMan Posted December 9, 2012 Posted December 9, 2012 If it's only the A string and only when open, then it's the nut slot is cut to deep. If it's only the A string and it buzzes up and down the neck, I suspect the string itself is bad.
MartyGrass Posted December 9, 2012 Posted December 9, 2012 Frank has built Fenders. He knows this stuff. As a general rule, a standard piece of paper should just squeeze under the string at the first fret when you hold the string down at the second fret. In other words, when fretting the second fret, a piece of paper should just clear between the first fret and the string. If the paper sticks, the nut is cut too deep or the first fret is too high. I have to admit to being stymied by a bad string that buzzed up and down the fretboard. I still can't explain why, but it can happen.
fretless Posted December 9, 2012 Posted December 9, 2012 I use feeler gauges when cutting the nut , so you would need to check that first at the 1st fret If correct then proceed on down the neck . As Blunote suggested it could be a fret down the neck somewhere that "lifted" . Check out some of John Carruthers YT's for nice setup tips .
DetroitBlues Posted December 9, 2012 Posted December 9, 2012 The nut can be fixed too with a little pencil shavings and superglue...
