big bob Posted December 17, 2012 Share Posted December 17, 2012 The sound city was turned on for 5 min or so w/o being connected to the cab. It works, but seems to hiss quite a bit louder than before. Any ideas what got cooked? Output transformer? Tubes? Caps? I can't really crank it up this late at night. So I guess I'm waiting for the tomorrow afternoon. Link to comment Share on other sites More sharing options...
HANGAR18 Posted December 17, 2012 Share Posted December 17, 2012 Oh crap. I hope there is no harm done. I don't know enough about tube amps to answer the question. Link to comment Share on other sites More sharing options...
DetroitBlues Posted December 17, 2012 Share Posted December 17, 2012 Oh boy! Not good. Check the tubes first I suppose... Link to comment Share on other sites More sharing options...
Steiner Posted December 17, 2012 Share Posted December 17, 2012 I'm not sure 5 min is long enough to cause harm unless it's turned up high. It seems to me that the trannys take the brunt with an infinite load. I hope you were drinking heavily at the time. Link to comment Share on other sites More sharing options...
big bob Posted December 17, 2012 Author Share Posted December 17, 2012 I'm not sure 5 min is long enough to cause harm unless it's turned up high. It seems to me that the trannys take the brunt with an infinite load. I hope you were drinking heavily at the time. No, it was just a stupid accident. I had jut set up another amp head on top of it, when I reached behind to set up the cables I must have switched on the sound city with my knee. I did not even know it was on for five min. Or so. The dials on the sound city wee all set at about 2. Link to comment Share on other sites More sharing options...
kbp810 Posted December 17, 2012 Share Posted December 17, 2012 Any reduction in power or sound quality? Or just the hiss? (of course I realize you won't be able to really answer that question until tomorrow afternoon) While your at it, with the amp on, start at a low volume level and slowly turn the volume up - take note on if the volume of the hiss also increases, or essentially stays the same. If it's just light hiss, your power amp section (power tubes and transformers) should be just fine - though if the hiss has become rather prevalent, it's possible a power tube may have been damaged and is arcing internally. Link to comment Share on other sites More sharing options...
big bob Posted December 17, 2012 Author Share Posted December 17, 2012 Any reduction in power or sound quality? Or just the hiss? (of course I realize you won't be able to really answer that question until tomorrow afternoon) While your at it, with the amp on, start at a low volume level and slowly turn the volume up - take note on if the volume of the hiss also increases, or essentially stays the same. If it's just light hiss, your power amp section (power tubes and transformers) should be just fine - though if the hiss has become rather prevalent, it's possible a power tube may have been damaged and is arcing internally. I'll know tomorrow, Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted December 17, 2012 Share Posted December 17, 2012 The sound city was turned on for 5 min or so w/o being connected to the cab. It works, but seems to hiss quite a bit louder than before. Any ideas what got cooked? Output transformer? Tubes? Caps? I can't really crank it up this late at night. So I guess I'm waiting for the tomorrow afternoon. Check to see if there is a cat in the back of the amp which could cause hiss. Dan Greenberg (Spectrum13) recently had that issue. Link to comment Share on other sites More sharing options...
yoslate Posted December 17, 2012 Share Posted December 17, 2012 Check to see if there is a cat in the back of the amp which could cause hiss. Dan Greenberg (Spectrum13) recently had that issue. Snakes...clearly. Snakes in the amp.... Link to comment Share on other sites More sharing options...
bolero Posted December 17, 2012 Share Posted December 17, 2012 was it just powered on, with no instrument connected? IMO as long as you didn't put a signal thru the amp it should be ok Link to comment Share on other sites More sharing options...
kbp810 Posted December 17, 2012 Share Posted December 17, 2012 Snakes...clearly. Snakes in the amp.... Not sure why I didn't think of it before, this is cleary the problem. You might not be qualified to correct this from your end - I highly advise taking the amp to Samual L Jackson who can help you get those mother f'n snakes out of the mother f'n amp. Link to comment Share on other sites More sharing options...
schundog Posted December 17, 2012 Share Posted December 17, 2012 Not sure why I didn't think of it before, this is cleary the problem. You might not be qualified to correct this from your end - I highly advise taking the amp to Samual L Jackson who can help you get those mother f'n snakes out of the mother f'n amp. Of course, another little known fact is that Samuel L. Jackson had his own line of beer; Here's his commercial for it, along with another great Samuel L. Jackson movie line.... Sorry, I got nothin' on the amp. Link to comment Share on other sites More sharing options...
kbp810 Posted December 17, 2012 Share Posted December 17, 2012 Of course, another little known fact is that Samuel L. Jackson had his own line of beer; Here's his commercial for it, along with another great Samuel L. Jackson movie line.... Sorry, I got nothin' on the amp. Sam Adams is one of my favorite beers (when Two Hearted or another IPA is not readily available), Dave Chappel and Samuel L Jackson are awesome, therefore that happens to be one of my favorite sketches of all time Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted December 17, 2012 Share Posted December 17, 2012 Sam Adams is one of my favorite beers (when Two Hearted or another IPA is not readily available), Dave Chappel and Samuel L Jackson are awesome, therefore that happens to be one of my favorite sketches of all time I dislike Sam Adams beer. It tastes like mud to me. However, I was drinking a couple of Oberons yesterday while watching the Falcons annihilate the Giants!~ Link to comment Share on other sites More sharing options...
Blunote Posted December 17, 2012 Share Posted December 17, 2012 Sometimes I'm even amazed at how many ways a thread can veer off track. Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted December 17, 2012 Share Posted December 17, 2012 Sometimes I'm even amazed at how many ways a thread can veer off track. Always seems to happen here doesn't it? Link to comment Share on other sites More sharing options...
kbp810 Posted December 17, 2012 Share Posted December 17, 2012 Sometimes I'm even amazed at how many ways a thread can veer off track. Just figured we had some time to kill before Big Bob got a chance to fire up the amp and put it through it's paces I dislike Sam Adams beer. It tastes like mud to me. However, I was drinking a couple of Oberons yesterday while watching the Falcons annihilate the Giants!~ I've only ever cared for the original Boston Lager, it's a great beer (not a fan of any of their other brews); if Boston Lager tastes like South Carolina mud, then I need to bring the Jeep down to SC and run it through a few of them mud pits! Link to comment Share on other sites More sharing options...
Thundersteel Posted December 17, 2012 Share Posted December 17, 2012 Samuel Adams used to be one of my favorite beers--until I tried Yuengling! Hey Lance--how's that amp coming along? Link to comment Share on other sites More sharing options...
big bob Posted December 17, 2012 Author Share Posted December 17, 2012 Won't know untill I get home and have a chance to fire it up. I have my fingers crossed. Link to comment Share on other sites More sharing options...
DetroitBlues Posted December 17, 2012 Share Posted December 17, 2012 Just figured we had some time to kill before Big Bob got a chance to fire up the amp and put it through it's paces I've only ever cared for the original Boston Lager, it's a great beer (not a fan of any of their other brews); if Boston Lager tastes like South Carolina mud, then I need to bring the Jeep down to SC and run it through a few of them mud pits! with a couple mugs hanging out the window... Link to comment Share on other sites More sharing options...
DetroitBlues Posted December 17, 2012 Share Posted December 17, 2012 Won't know untill I get home and have a chance to fire it up. I have my fingers crossed. Back to the original subject... Good Luck Lance! Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted December 17, 2012 Share Posted December 17, 2012 Just figured we had some time to kill before Big Bob got a chance to fire up the amp and put it through it's paces I've only ever cared for the original Boston Lager, it's a great beer (not a fan of any of their other brews); if Boston Lager tastes like South Carolina mud, then I need to bring the Jeep down to SC and run it through a few of them mud pits! Only if you bring the 157 and a KBPamp!!! Link to comment Share on other sites More sharing options...
big bob Posted December 17, 2012 Author Share Posted December 17, 2012 Well I had a chance to really crank her up today. The hum/hiss was louder than normal when I first powered her up but after a while it went back to normal. The hum/hiss did not get louder with volume increase. And I cranked her up pretty loud. After a while she seemed normal.. Looks like I dodged a bullet on this one. Thanks for keeping me sane while I waited. Link to comment Share on other sites More sharing options...
Steiner Posted December 17, 2012 Share Posted December 17, 2012 Can you post a picture of the hum with your Ipad? Link to comment Share on other sites More sharing options...
Blunote Posted December 17, 2012 Share Posted December 17, 2012 That Steiner is such a jokester. Stop jokin' me man! Link to comment Share on other sites More sharing options...
