H Posted March 16, 2013 Posted March 16, 2013 Newly revitalised amp day The Limey had developed a nasty little mosquito buzz when playing an E so I took some time today to tighten up all the nuts, bolts, screws and adjusted the position of a few components and wires. She's now sounding glorious again There's a bit of work coming up on the H-O-Lux tomorrow if everything works out all right. Look out for some action on that thread
Gitfiddler Posted March 16, 2013 Posted March 16, 2013 Great photo, H. Strange buzzes, vibrations and noises can drive you nuts on an amp. Good that you found and corrected yours quickly.
bolero Posted March 16, 2013 Posted March 16, 2013 +1 on the photo!! what kind of camera are you using?
H Posted March 16, 2013 Author Posted March 16, 2013 +1 on the photo!! what kind of camera are you using? iPhone 4
schundog Posted March 16, 2013 Posted March 16, 2013 Sigh, I love your Limey, ya Limey! I agree, fantastic picture. What's your best guess on what was causing the buzz? Loose screws/nuts or the other adjustments you had to make? Curious as to what in particular you had to reposition. I'm enjoying the H-O Lux thread, too, Howard.
H Posted March 16, 2013 Author Posted March 16, 2013 There was a resistor one of the power tubes that was a bit close to the chassis. I moved all the big caps apart so they can't vibrate against each other - considering putting a blob of plumbers' mastic inbetween all the relevant caps to make the gap permanent. Tightened the screws that hold the fibreboard to the chassis and put a drop of Loctite thread locking fluid on each of them. Here's another pic
H Posted March 16, 2013 Author Posted March 16, 2013 Best guess is the slack nut on the output jack. I'm guessing the chassis is 'tuned' to E and vibrates sufficiently on that note to loosen things and cause the mosquitoes
Steiner Posted March 17, 2013 Posted March 17, 2013 Man, H, that wood gives me a, well, let's say a warm feeling. That is a stellar cab! You did one hell-of-a good job stretching the grille cloth too. If she sound half as good as she looks, you've gotta be floating in a sea of nirvana! Have at thee!
