P-rails for Shallers on the Little One
gpuma
I am playing with the idea of replacing the stock Shallers pick up I have on the Heritage Little One with P-Rails.
I have a couple of questions:
1) do they fit?
2) the little one electronics consists of 2 volumes. Each pot is push/pull to spilt coils. How can you control p-rails with such a config? Should I just forget about it and get their dedicated pickup rings?
3) is it possible to install chrome covers?
P-Rails will fit any standard humbucker route. The easiest way to get them wired is to use the triple shot rings, you can have up to 4 wiring choices then for each pickup. Covers will not fit P-Rails.
I am of the opinion that you try to balance out the natural tonal characteristics of the guitar with the pickup's designed frequency curve, which is usually listed on the manufacturer's website..
You know what is in the guitar to begin with and you can judge the degree of brightness/darkness that you are hearing and is already there with that combination. If the guitar is small, uses a large chunk of bright tonewood such as maple, or for whatever reason is naturally bright, you use a darker pickup to compensate and bring the output back into tonal balance. The same goes in the other direction. So assess what you have in the beginning and move from there.
The penalty is spending money to find you have an overly bright or dark guitar.
1) Probably fit
2) Triple-shot or give up a combination
3) Don't think so
the little one cotrol cavity is very small....not much room to solider
I know but would you think that a professional would not do it? Maybe this is something I need to check...
Yes and I'm a member of the CSFS Club
Can't solder for ...
I think it was your guitar I did those on?
Yes the ASAT Deluxe I think. Actually that guitar had a single volume and tone control with a mini switch to split the original humbuckers.
It now has P-Rails and Triple shots. The mini switch is still there but not connected.
Which inspired this 170 with P-Rails
Both the video above and my 170 were done before the triple shots were released. The middle mini switch on mine is not connected, the two other two way switches were replaced with three way switches so I have series / rail and P-90 for each pickup. No parallel option with this setup which is actually a very useful tone, it's lower in output than series and very clear but still humbucking.
The single coil tone ( rail) in the 170 is nothing special, not surprisingly the rail tone is a lot more convincing in the ASAT pictured above.
