SlappyTappy Posted April 23, 2013 Posted April 23, 2013 So I've researched plenty a topic on different wiring techniques, IE Gretsch "independent" wiring, Gibson wiring (/w 50s tone cap wiring), etc. I'm also still very much a Fender lover at heart. I love the simplicity of a master volume, master tone, 3 way switch and be done with it! However, in my experience the Independent Gretsch wiring kills a guitars top end the moment you start rolling down the volume pot. My question is: is there any similarly discernible difference in wiring a dual humbucker guitar with 2vol/2tone vs. master vol/tone? I personally can't recall noticing a difference difference with similar guitars I've played. Maybe some of you fine folk can shed some light on it.
212Mavguy Posted April 23, 2013 Posted April 23, 2013 Traditional 2v2t does roll off top end with a reduction from max on the volume pot. Some folks solder a capacitor across the pot terminals to correct this behavior. I'm not sure about the value, thinking that values used for a "bright switch" are appropriate, 100-500 picofarad range.
TalismanRich Posted April 24, 2013 Posted April 24, 2013 I put a treble bleed on both my 535 and 157. I haven't done the 140 or Mille yet. It really does smooth out the response. Here's the thread. http://www.heritageownersclub.com/forums/topic/5115-treble-bleed-on-a-157/?hl=%2Btreble+%2Bbleed Mojotone wiring harnesses also have a treble bleed incorporated into the setup. http://www.mojotone.com/guitar-parts/guitar-wiring-kits-gibson-style If you want to see how it affects the frequency response of a guitar, download the file GuitarFreak 2.2. You put in the type of wiring, the resistance, inductance and the values of the pots, etc. It will show how peaky a guitar's response really is. http://guitarnuts2.proboards.com/index.cgi?board=reference&action=display&thread=3627
SlappyTappy Posted April 24, 2013 Author Posted April 24, 2013 This is all good info but not really addressing my question of the difference between traditional "Gibson" wiring and a master volume/master tone setup. That program is fascinating but way above my technical knowledge
Steiner Posted April 29, 2013 Posted April 29, 2013 On 4/24/2013 at 3:43 AM, TalismanRich said: I put a treble bleed on both my 535 and 157. I haven't done the 140 or Mille yet. It really does smooth out the response.ere's the thread. http://www.heritageownersclub.com/forums/topic/5115-treble-bleed-on-a-157/?hl=%2Btreble+%2Bbleedojotone wiring harnesses also have a treble bleed incorporated into the setup.ttp://www.mojotone.com/guitar-parts/guitar-wiring-kits-gibson-stylef you want to see how it affects the frequency response of a guitar, download the file GuitarFreak 2.2. You put in the type of wiring, the resistance, inductance and the values of the pots, etc. It will show how peaky a guitar's response really is.http://guitarnuts2.proboards.com/index.cgi?board=reference&action=display&thread=3627 Beautiful post TalismanRich!
rockabilly69 Posted April 29, 2013 Posted April 29, 2013 On 4/24/2013 at 11:37 AM, SlappyTappy said: This is all good info but not really addressing my question of the difference between traditional "Gibson" wiring and a master volume/master tone setup. That program is fascinating but way above my technical knowledge Well I own a Gretsch with the Master (Chet Atkins 6122-1962), and plenty of the Gibson style 2vol/2tone setups. If the 2vol/2tone guitar is wired 50's style (tone caps to the middle leg of the volume pots, and center legs grounded on the tone pots) I think it retains highs better.
H Posted April 29, 2013 Posted April 29, 2013 On 4/29/2013 at 10:04 PM, rockabilly69 said: Well I own a Gretsch with the Master (Chet Atkins 6122-1962), and plenty of the Gibson style 2vol/2tone setups. If the 2vol/2tone guitar is wired 50's style (tone caps to the middle leg of the volume pots, and center legs grounded on the tone pots) I think it retains highs better.I've got the Gibson take on rockabilly69's Gretsch and I'd agree with his opinion here.
rockabilly69 Posted April 30, 2013 Posted April 30, 2013 That's a beaut H, that single cut looks great! My Chet is the double cut, and the neck seems to sit way out there:) It took me a while to get used to it. But the Bigsby works great on it, and it is the only Bigsby I've used that stays in tune. I've had particularly bad luck with all things Bigsby!!! I also love the Filtertrons when playing through EL84 amps! Here's mine...
SlappyTappy Posted April 30, 2013 Author Posted April 30, 2013 Ok maybe I didn't state myself as well as I thought. I'm asking if a GIbson style control setup (2vol/2tone) sounds relatively similar to a guitar with a master vol/master tone setup IE only two knobs.
H Posted April 30, 2013 Posted April 30, 2013 On 4/30/2013 at 12:52 AM, SlappyTappy said: Ok maybe I didn't state myself as well as I thought. I'm asking if a GIbson style control setup (2vol/2tone) sounds relatively similar to a guitar with a master vol/master tone setup IE only two knobs. Yes, it does. There's just no 'mix' capability between the pickups so it's a less versatile setup.
