Neck Angle, Height of neck at base relative to guitar body
ely
Hi, Anyone know what the neck angle at the base on H535 should be - approx or dead on- has anyone lowered the bridge to the bottom and not had the action low enough for how they like it.
Cheers,
Ely
Hey Bob,
Always. Would you mind posting a measurement from top of 12 fret to bottom of low and high E. Im trying to get to the bottom of a couple of issues.
Cheers.
I had a hard time seeing the Steele, so I'm not sure if this will help looks like just less than 1/16 low e and about 1/32 + on the high.
My glasses are kinda old so I had a real hard time.
It could go lower but would hit the frets..
Cheers,
Ely
Hi Ely, I'm H from Essex :) Congratulations on your new 535. Sorry to hear about the issues you've found.
The 535 is obviously modelled on a late 50s Gibson 335. It shares many characteristics including a neck angle of 4 to 5 degrees.
However, this is not the only consideration here: you mentioned a poorly cut nut, this will have an impact as will truss rod adjustment.
Finally, the height at which the neck is attached to the body has a large bearing on the adjustment for the bridge.
I understand your frustration about this but I believe a good set-up will get you back to what should really be happening now: you enjoying playing a quality handmade instrument.
