212Mavguy Posted July 17, 2013 Share Posted July 17, 2013 Not sure about the K130 played with dirty tones. Haven't owned one of those, my ears lack experience in front of them. The speakers I posted do those tones exceptionally well in my experiences as well as clean. No slight intended. Link to comment Share on other sites More sharing options...
mars_hall Posted August 1, 2013 Share Posted August 1, 2013 Got me thinking, so I went out and bought a used EVM-15L tonight that I'll drop in a cabinet. Not sure if I will do one from scratch in a Thiele upsized design or whether I will used an old 24x19x19 I built back in another lifetime. It currently has a 12'' in it, but I can resize the hole. Either way, when I use that for bottom and a a 2x12 V30 cabinet I built for the upper range, I'm thinking it should sound OK and be portable. http://hf-antenna.com/Flotsam/EV/ElectroVoice_TL806.pdf Link to comment Share on other sites More sharing options...
111518 Posted August 1, 2013 Share Posted August 1, 2013 Got me thinking, so I went out and bought a used EVM-15L tonight that I'll drop in a cabinet. Not sure if I will do one from scratch in a Thiele upsized design or whether I will used an old 24x19x19 I built back in another lifetime. It currently has a 12'' in it, but I can resize the hole. Either way, when I use that for bottom and a a 2x12 V30 cabinet I built for the upper range, I'm thinking it should sound OK and be portable. http://hf-antenna.com/Flotsam/EV/ElectroVoice_TL806.pdf ...sounds like the speaker array I end up with when I use my Riviera BM100-15 (which has an EV) sitting on a 2-12 V30 closed cab. I really like the combination; I think the different characteristics of the speakers compliment each other well. Link to comment Share on other sites More sharing options...
mars_hall Posted August 10, 2013 Share Posted August 10, 2013 Got me thinking, so I went out and bought a used EVM-15L tonight that I'll drop in a cabinet. Not sure if I will do one from scratch in a Thiele upsized design or whether I will used an old 24x19x19 I built back in another lifetime. It currently has a 12'' in it, but I can resize the hole. Either way, when I use that for bottom and a a 2x12 V30 cabinet I built for the upper range, I'm thinking it should sound OK and be portable. http://hf-antenna.com/Flotsam/EV/ElectroVoice_TL806.pdf Finished with the job and it wore me out, manually screwing dry wood (36 holes), but I was anxious to get it knocked out and got good results. Sounds very close to the Thiele cabinet, but this is more of a straight ported design. Perhaps a slightly loud bottom, but since it is an EV and not the 15B, it has crispness also. Bought an EVM-18B last night which I will use for a bass rig, matching it up with the Thiele or 15L for the upper register. If you are going to be a bear, be a grizzly. Link to comment Share on other sites More sharing options...
212Mavguy Posted August 12, 2013 Share Posted August 12, 2013 niiiiiiiice! Link to comment Share on other sites More sharing options...
JohnCovach Posted August 12, 2013 Share Posted August 12, 2013 I've got two Weber JBL clone 15s in my Dual Showman Reverb cab that I use with the Yes band. When I can crank that amp a bit (usually at outdoor shows), those speakers deliver a very balanced tone with more bass definition than any of my other cabs. They do a pretty god job at lower volumes, but there's less difference and they can get a bit "wooffy." Link to comment Share on other sites More sharing options...
