New American Eagle Porn and Info
MartyGrass
Jim Deurloo said that the pickup on the American Eagles were different from any other jazz pickup they used. He said they were custom wound for them and the final assembly was done there at the Heritage plant. Magnets and other components were different from the others. He wasn't too sure which magnets were used but said Ren will know.
I will get the guitar in less than a week. I just received new pix to share.
DSC01556_zpsb158c232.jpgDSC01554_zps7f070fca.jpgDSC01551_zpsfda1aed2.jpgDSC01552_zps552770c9.jpgDSC01539_zps22980069.jpgDSC01550_zps8cf04c7d.jpgDSC01548_zpse02104e9.jpgDSC01540_zps8ce28ec8.jpgDSC01549_zps0b55bfaa.jpgDSC01541_zps02d8f2f7.jpg
Amazing. Premium in every aspect. Just imagine how good she sounds....
Some amazing wood in that one. Enjoy!
I have always liked the American Eagles, ever since I became really close with Heritage....its a flagship of what they stand for
Mark, it appears there is quite an extensive label inside the body. Does it describe the background of the build? It is certainly a magnificent tribute to the Heritage legacy, and it's namesake.
The shots that show the RWB binding are very cool and the back shots show some beautiful figured maple.
But the money shot for me is that first one, as it shows off the various woods quite nicely.
I'll post the label when I get the guitar.
I cant imagine the amount of hours it took to build that....just an amazing piece
What a piece! If you didn't want to swim in that pool for some reason, I think you just might be able to swim in the figured maple on the back. Lucky fellow!
Wow, looks like the pickguard is also done the same.
In 1994, when this was made, Heritage did w-b-w-b-w-b-w by the fretboard and w-b-w-b-w around the headstock on the Golden Eagles and Supers. Marv recently said that didn't allow a flow from the headstock to the cupid's bow. The newer GEs and SEs have resolved that by using the same layers of binding for the headstock and the neck.
The American Eagle never had that issue because it was restricted to RWB everywhere.
Here's an older SE. Note the transition from the headstock to the fretboard. It jumps from two black stripes to three. Some found that awkward aesthetically.
Also note that the junctions of the binding at the top sides of the headstock are sharp angles, not rounded. The old Gibson guys worked hard to make the angles sharp and look down at some of the work coming out of the Gibson Custom Shop.
Here's a Heritage:
Here's a recent Gibson. It's hard to see but the corners are rounded. Aaron Cowles frowned when I showed him this, then he explained that there's no good excuse for this sloppiness. Hey Aaron, that's MY Gibson you're degrading! He wouldn't stop.
T2eC16ZUE9s3wDd4BRRONUU2g60_57_zps765e31
Tim likes big bouts.
A little trivia: The so called 17" bouts are really slightly less than that. The usual Golden Eagle is 16 7/8" For some reason this American Eagle is slightly wider at 16 15/16", believe it or not.
How classy is that? Definitely a Wow Factor!!
