jamison162 Posted September 2, 2008 Posted September 2, 2008 I've got several small (almost tiny) blemishes on my H-150 Goldtop. I keep hearing Nitro is easy to touch up....anyone done this with success?
big bob Posted September 2, 2008 Posted September 2, 2008 stewmac sells nitro touch up supplies. Dan Erlwines book explains how to, looks easy but I have not tried it
slider313 Posted September 3, 2008 Posted September 3, 2008 stewmac sells nitro touch up supplies. Dan Erlwines book explains how to, looks easy but I have not tried it I've done it more than a few times when I worked for SMASH. The laquer "pens" are like a magic marker. The bigger the "doink" the more applications it will take. Let the first touch up dry for 15 min. and do it again if needed. Sometimes one application is all it takes.
big bob Posted September 3, 2008 Posted September 3, 2008 have any of you guys used the sticks ( you know you light them on fire, blow em out and then fill chips) sorry for the shitty discreption..
jamison162 Posted September 3, 2008 Author Posted September 3, 2008 StewMac deosn't have a gold lacquer stick though...
tulk1 Posted September 3, 2008 Posted September 3, 2008 StewMac deosn't have a gold lacquer stick though... Wouldn't it be the paint underneath that is gold? The lacquer should be clear.
jacques Posted September 3, 2008 Posted September 3, 2008 and how about that red colour on the back of my 150...the paint came off there and before touching up with nitro I need to restore that first...anyone?
cook Posted September 7, 2008 Posted September 7, 2008 I have found that in theory nitro is easy to touch up, but it in reality it takes a lot of care and effort to make it look unnoticeable. Levelling and polishing the touchup usually will alter the surrounding buffed fininsh and if you're buffing by hand it will look different than the factory buffed surrounding finish. I also recommend getting some tips from Erlewine's book. I hope I didn't discourage you, because you can make the touch up look good. Good luck!
