Show and tell! H-150,,,,,h157
holyroller
  • Replies 92
  • Created
  • Last Reply
I'd guess a dark almond burst. Might be way off the mark though as I'm not sure that finish was available in 1992.
The sticker inside says ASB which I believe is Antique sunburst.
You should maybe think of getting that guitar on a t shirt design at some point :icon_sunny:
hahahaha....!
  • 1 month later...
My 150 VSB
I really like that one, what's the bridge pup?
H150 CM, OSB, Duncan 59 neck Pearly Gates bridge
H150P Black Duncan JB/Jazz set.
Sorry for the crappy pics.
If you look behind the 150p you can see th monster KBP tweed!
Oooops missed the question .... it has a pair of Duncan Pearly Gates with a jonesy blues Jimmy Page wiring harness ... 4 push / push pots and about 20 different tones. It had already been customised when I bought it used.
To be honest I didn't like the PGs at first, they sounded too thin. I adjusted them a little closer to the strings and hey presto they fattened up nicely. Only moved them by 2mm or so ( 1/8" = 3mm ) but it made all the difference.
http://www.jimmypagewiring.com/Home_Page.html
I don't use anywhere near 21 tones, there are several very cool sounds in there though.
So it's a 150 or 157 now ? Thought this was going to be a Milie ? :icon_scratch:
It was for about a milli-second.
I guess it's now a cross between a 150 and a 157, a 153 1/2 if you will.
H157 with the H150 rounded radius on the rear of the body?
if so, good idea!! some ppl get annoyed but the angular back edge on a LPC or H157
One of each. I recently replaced the plastic bits on the 150, now they match nicely. It has Bareknuckle Stormy Mondays, courtesy of Golferwave, bought on e bay prior to my discovering the HOC.
