Guest HRB853370 Posted October 3, 2013 Share Posted October 3, 2013 Took the amp to my amp tech (an authorized Peavey service guy) on Tuesday, got it back today. Appreciated the quick turnaround, paid the $60 he charged, got it home, plugged it in, and in less than 5 minutes of playing it, it died exactly the same as the first time. No tubes lit, but pilot lamp is lit. When he had it the first time, he said the fuse was fine, but he got it to come back on by resecuring the tube sockets and then he said he re soldered down the line because on a Peavey Delta Blues, the tubes are chained together like a string of christmas tree lights-one goes, they all go. I guess I will have to take it back tomorrow. He gave me a one year warranty on his work (not counting tube failure). I just hate the inconvenience! Link to comment Share on other sites More sharing options...
bolero Posted October 3, 2013 Share Posted October 3, 2013 here ya go... cost = $5.00 to rent, will fix the problem permanently Link to comment Share on other sites More sharing options...
Gitfiddler Posted October 3, 2013 Share Posted October 3, 2013 I recommend playing the CPA Card... Charge your tech mileage to and from his shop for each follow up visit due to his lack of due diligence. Link to comment Share on other sites More sharing options...
slider313 Posted October 3, 2013 Share Posted October 3, 2013 I recommend playing the CPA Card... Charge your tech mileage to and from his shop for each follow up visit due to his lack of due diligence. and a free set of power tubes for your trouble. Link to comment Share on other sites More sharing options...
HANGAR18 Posted October 3, 2013 Share Posted October 3, 2013 Soak in water to make sure it doesn't catch on fire. Oops... Mama said If you can't say anything nice about Peavey amps, don't say nothin' at all. Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted October 3, 2013 Share Posted October 3, 2013 I took the tube cage off, powered it up, pushed on each tube to see if that would cause any to light up, nothing. That was his recommendation before bringing it back in. What was so weird was he had the amp on all night last night, then plugged a guitar in this morning, and it was fine. It was playing fine when I picked it up. I get it home, power it up, plug in a guitar, and after less than 5 minutes its gone again. Just plain freakin weird. Link to comment Share on other sites More sharing options...
HANGAR18 Posted October 4, 2013 Share Posted October 4, 2013 I took the tube cage off, powered it up, pushed on each tube to see if that would cause any to light up, nothing. That was his recommendation before bringing it back in. What was so weird was he had the amp on all night last night, then plugged a guitar in this morning, and it was fine. It was playing fine when I picked it up. I get it home, power it up, plug in a guitar, and after less than 5 minutes its gone again. Just plain freakin weird. Irregular voltages at your residence? Surges, fluctuations or maybe above 110 volts? Link to comment Share on other sites More sharing options...
HANGAR18 Posted October 4, 2013 Share Posted October 4, 2013 Irregular voltages at your residence? Surges, fluctuations or maybe above 110 volts? Improperly grounded receptacles? Link to comment Share on other sites More sharing options...
Blunote Posted October 4, 2013 Share Posted October 4, 2013 Sounds like the sort of thing that happens when a connector or cable (especially those pesky ribbon cables) breaks. Link to comment Share on other sites More sharing options...
HANGAR18 Posted October 4, 2013 Share Posted October 4, 2013 Sounds like the sort of thing that happens when a connector or cable (especially those pesky ribbon cables) breaks. So jiggle the ribbon cable to see if it suddenly works again? Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted October 4, 2013 Share Posted October 4, 2013 So jiggle the ribbon cable to see if it suddenly works again? There is no visible ribbon cable. Link to comment Share on other sites More sharing options...
golferwave Posted October 4, 2013 Share Posted October 4, 2013 With that pesky warning label on the back about "no user serviceable parts" I think I'd just wait for the tech. Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted October 4, 2013 Share Posted October 4, 2013 With that pesky warning label on the back about "no user serviceable parts" I think I'd just wait for the tech. I didn't see such label, but I am not opening up the chassis. Link to comment Share on other sites More sharing options...
golferwave Posted October 4, 2013 Share Posted October 4, 2013 I didn't see such label, but I am not opening up the chassis. Good plan! Link to comment Share on other sites More sharing options...
Blunote Posted October 4, 2013 Share Posted October 4, 2013 There is no visible ribbon cable. Most solid state amps with pc boards have them. It's common enough that the wires inside come loose or break. That, or connections to sockets, or other components break. There's a lot of heat generated inside an amp that cause parts expand and contract. Over time, they sometimes fail. Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted October 4, 2013 Share Posted October 4, 2013 Most solid state amps with pc boards have them. It's common enough that the wires inside come loose or break. That, or connections to sockets, or other components break. There's a lot of heat generated inside an amp that cause parts expand and contract. Over time, they sometimes fail. Exactly Blunote, there are 3 pc boards inside there and lots of jumpers, etc. Its a crapshoot and ANYTHING can go wrong. The good part is he wont charge me anymore but he may have it a while, which is ok, as long as it come back fixed! Link to comment Share on other sites More sharing options...
Joe Posted October 4, 2013 Share Posted October 4, 2013 Most solid state amps with pc boards have them. It's common enough that the wires inside come loose or break. That, or connections to sockets, or other components break. There's a lot of heat generated inside an amp that cause parts expand and contract. Over time, they sometimes fail. My Delta Blues used to get so hot it scared me. I finally rigged up a cooling fan and I would run the fan between sets. I did have the amp serviced once before I rigged the fan, but never after that. Probably went overboard with the size of the fan, it keeps the amp too cool to let it run continually. My Classic 50 has an internal fan and never gets hot. Since they both use the same tube configuration, they probably generate the same amount of heat. Mabee that's a design oversight. Link to comment Share on other sites More sharing options...
DetroitBlues Posted October 4, 2013 Share Posted October 4, 2013 You mean the Delta Blues is the only amp you have? I thought you had some other fun toys to use? Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted October 5, 2013 Share Posted October 5, 2013 You mean the Delta Blues is the only amp you have? I thought you had some other fun toys to use? Yes DB I do. I have been playing my Gibson GA40RVT more now, its a Class A hand wired amp and it just sounds incredible. Its heavy though, heavier than even the Delta. I also have my Deluxe Reverb RI. Link to comment Share on other sites More sharing options...
DetroitBlues Posted October 5, 2013 Share Posted October 5, 2013 Yes DB I do. I have been playing my Gibson GA40RVT more now, its a Class A hand wired amp and it just sounds incredible. Its heavy though, heavier than even the Delta. I also have my Deluxe Reverb RI. Then you've got nothin to worry about. Besides, you can find those amps used for $300. I think you're getting close to that. I'd consider buying it broken and turned into a Bassman Combo... Link to comment Share on other sites More sharing options...
barrymclark Posted October 6, 2013 Share Posted October 6, 2013 I recommend the Cube. Just messing with you. That does really stink when an amp you dig goes down. Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted October 6, 2013 Share Posted October 6, 2013 UPDATE! Amp tech called me this morning, he diagnosed it as the power transformer shot. He said he thinks there is a 5 yr warranty and should be able to get one for free since he is an authorized Peavey repair center! Link to comment Share on other sites More sharing options...
barrymclark Posted October 6, 2013 Share Posted October 6, 2013 UPDATE! Amp tech called me this morning, he diagnosed it as the power transformer shot. He said he thinks there is a 5 yr warranty and should be able to get one for free since he is an authorized Peavey repair center! Well, that's cool and it sucks too. Sucks that it happened.. but cool it is covered! Hey, if it is gonna fry, please let it fry under warranty. Link to comment Share on other sites More sharing options...
tulk1 Posted October 9, 2013 Share Posted October 9, 2013 If it isn't covered, think Hyboer or Magnetic Components for replacements. Don't get sucked into the Mercury Magnetics hype. Link to comment Share on other sites More sharing options...
Guest HRB853370 Posted October 22, 2013 Share Posted October 22, 2013 New transformer (OEM) on warranty, amp is back in service!!! I was only charged the labor. Link to comment Share on other sites More sharing options...
