Is this H555 overweight?
MartyGrass
It weighs 8.2 lbs naked and dry. How does that compare to H535/555s out there?
The guitar is sensitive because someone claimed it is extremely heavy.
My '08 555 in at 8.1
my '02 535 reads 7.7
Extremely heavy?... Would guess it's within a couple sigma.
Since Heritage uses solid rims, would that make them more heavy than other semis?
Also, if the 555 has a fat profile Mahogany neck it would add to the weight.
It's a little heavier than I'm used to in this style of a guitar. But it's comfortable all right.
Thanks to Jack for this great instrument!
Here are some non-glam shots. The flame is subtle only because cherry doesn't flaunt it!20131022_144003_zps80242811.jpg20131022_144017_zps7687cb72.jpg20131022_144056_zpsa461bbde.jpg
Heritages are thinner than Gibsons so the center block should be lighter.
I didn't know the Gibson rims are laminates. I thought that laminates crack too often when shaped for rims.
It's a mystery alright.
The question sounds close to "Does this dress make me look fat?"
I'll weigh my 555 and 535 fat ass, I mean fat neck when I get home tonight.
Its chubby, but in the right places.... my 535 weighs in at a hefty 8.11 lbs. Its a 2005 model.
Moreso than the weight, it seems that the balance of the guitar makes a difference. My 535 feels almost like my Mille, but thats only 7.6 lbs. Then again, it might be that the 535 sits on the "shelf" I provide differently!
Obligatory glamor shot.
you could always put an aluminum ( aluminium for you Brits ) tailpiece on there, and shave off nearly a pound
If you play it frequently it will lose weight!
My 353 is quite heavy also. I'll weigh it when I get home.
its actually only 7.75 lbs....feels more stout than that though
That's one sharp looking git!
Is that faded cherry or cherry? The top seems lighter than the sides.
That one is faded cherry. Its a bit more translucent that the normal cherry. The only reason the top looks lighter is because of the flash. Its pretty much all the same shade, top, back and sides.
