Schaller Tailpeice studs...
DetroitBlues
I think the Schaller stuff is metric, do you have metric Stoptail studs?
The old Schaller studs are too short for normal tailpeice. Must be metric studs...
The tailpiece studs on a 150 are Imperial (inches and standard subdivisions) unless your guitar has been modified, i.e., the inserts in the wood have been changed.
Why did you need new studs? When I did that swap on my 150 I used the original studs.
Blues - I got nothing except when you put tailpiece in your titles, you're going to get a whole bunch of thread hits. :)
I have done this once but it worked well. I used a metal dowel to force the bushing out.
Good luck Josh, Call me if you need help.
That did the trick, new studs are in place. However, I discovered a new problem. The saddles are preslotted Tonepros, and like all preslotted saddles, they're not right. Looks like it's going in for a little work after all. :(
Oy! Been through this on both Heritage guitars I converted. Stew Mac makes a tool for pulling knobs that works well for pulling bushings. I ended up buying a bridge with un-slotted saddles and paying my local tech to install it. It is not as simple as it seems to convert these to TOM style hardware.
that sucks, I never buy preslotted saddles for that very reason
I have a chunk of soft wood ( pine ) with a hole drilled out larger than the stud diameter....I put that on a cloth on top of the gtr and then with a long bolt & some washers the studs pull right out
the screw method is easy but on a thin gtr/deep stud it could push thru...also it will push into the wood which I'm not overly fond of, but maybe I'm just picky
