Killed it!
I left my Traynor on stand by for a couple days... Needless to say, it's not doing so hot. Tubes light up, but there barely is any sound and it's crackling like a loose wire.... Tubes perhaps?
Dude…a couple of days? I would definitely suspect tubes.
Call Dean Zink @ 248-681-5104 he's not far from you at all in Keego Harbor.
If you have spares, stick them in.
The tube heaters are on, but there is no voltage applied to the plates of the power tubes. it's not healthy for it but it shouldn't have killed the amp if you did that.
I would definitely take it in stat to see what has happened.
If you fried the tubes after a couple of days on standby (idle, reduced power) then you were past due for a new set. Get some quality tubes and you'll be set.
Why did you do that? Just to keep them warm when you came back to play it?
Tubes aren't too bad to swap, just be sure to check/adjust your bias (if this applies). You might find a new love with the new tubes in place ;)
I've left my amps on overnight sometimes. Haven't fried anything yet.
I'm sure it will be ok with new tubes. Call Brian. Or if he's too busy, I've used Dean Zink. He's good.
I once left my Guild amp on for almost a week. Didn't hurt it a bit. There is tube equipment that is left on 24/7 without damage. Two days shouldn't be a major problem unless one of the tubes was weak to start with.
preamp tubes usually last years and years and years...unless they get damaged by mechanical shock or something
if I were you I would bring it to a tech & get it a clean bill of health
Same here with my AC30CC1 and they were known for running hot.
My guess is a sloppy solder joint got hot and got sloppier. Mostly guessing that because everyone else has said tubes. ..... :)
Bad power tube... I think they were used, thankfully I had a set of old ones I found but forgotten I had. Ordered a new set, should be here in the next few days.
I don't get it...
This was in reference to replacing your bad power tube. My guitars always sound much brighter and alive when I change their strings, new tubes should breath new life into your amp. Unless of course the old tubes sing the blues better ;)
