barrymclark Posted January 28, 2014 Posted January 28, 2014 PRODUCT DESCRIPTION The new JazzAmp Head features two completely independent pre-amps, each with the same features as our popular combo amplifiers. This allows for two instruments to be plugged in at the same time with independent EQ for each instrument, or you can use with both pickups on a hybrid guitar and adjust the EQ to each pickup. You can also run a split signal to the amp, keeping one channel clean and one running through an effect chain or processor, allowing you to EQ the end of your effect chain separately from your clean signal. Each channel's line out is also independent, which allows you to run each channel separately to a board or recording device. You can also run pre-recorded tracks into one channel without that signal interfering with your instrument signal. Size: 11" X 9" X 3", 7 lbs. Controls: Volume, 5-band graphic equalizer, reverb with on/off switch and wet/dry mix control per channel. Power: Maximum power is 160 watts at 4 ohms. Warranty: Full 2 year warranty (see details on warranty page). Line Out: Each channel has independent line out. Speaker outputs: Two parallel 1/4" speaker jacks. 230v/115v Selector Switch: Yes http://www.henriksenamps.com/jazzamp-2-channel-head/ Sent from my SCH-I605 using Tapatalk
peterbright Posted January 28, 2014 Posted January 28, 2014 WOW! I want one. Other than a Henriksen cab, what would be the ultimate after market speaker? I use Webers for my tube amps but they are not rated for 160 watts.
barrymclark Posted January 28, 2014 Author Posted January 28, 2014 Red Stone. http://www.redstoneaudio.com/products.html If I got an H head, that's what I'd get Sent from my SCH-I605 using Tapatalk
peterbright Posted January 29, 2014 Posted January 29, 2014 Now that 12" is very interesting and not that expensive. Any ideas on the price of the head?
barrymclark Posted January 29, 2014 Author Posted January 29, 2014 799 Sent from my SCH-I605 using Tapatalk
peterbright Posted January 29, 2014 Posted January 29, 2014 Thats only $100 more than the single channel!
barrymclark Posted January 29, 2014 Author Posted January 29, 2014 Yeah. They're amps are well priced Sent from my SCH-I605 using Tapatalk
peterbright Posted January 29, 2014 Posted January 29, 2014 I am very tempted, but can't find a single channel to buy much less one of the new ones.
barrymclark Posted January 29, 2014 Author Posted January 29, 2014 Yeah. They discontinued single channel head awhile back. I think they said the 2ch will be available soon. Sent from my SCH-I605 using Tapatalk
barrymclark Posted January 29, 2014 Author Posted January 29, 2014 There are no Henriksen dealers anywhere near me so the only ones I will see are on the net. I believe you can buy direct from Henriksen Sent from my SCH-I605 using Tapatalk
barrymclark Posted January 29, 2014 Author Posted January 29, 2014 Their website isn't showing it yet. Click on that link in the first post. I believe you can pre order there. Oh, if memory serves, the Red Stone cab was developed using several guitars at least one of which was a Heritage. Sent from my SCH-I605 using Tapatalk
peterbright Posted January 29, 2014 Posted January 29, 2014 It should be available soon according to that.
barrymclark Posted February 8, 2014 Author Posted February 8, 2014 Now shipping http:// http://www.henriksenamps.com/jazzamp-2-channel-head/ Sent from my SCH-I605 using Tapatalk
