Show me your vintage spec 150s!
MrPoobah
Any of you guys into old school? vintage specs? Fat necks, sunbursts, PAFs, lets see em!
  • Replies 61
  • Created
  • Last Reply
it's a '94, so a medium neck, but I suppose it's vintage spec otherwise?
Wolfetone Legend PAF's
Pigtail steel studs & inserts
lightweight aluminum tailpiece
ABR-1 bridge
cherry sunburst
it is a killer H150
Freaking gorgeous. Am I weird for thinking they look best with a pick guard?
I would consider vintage spec to be anything that would have been found stock on a 50s LP. Fat neck, sunburst, gold, or black top, paf pickups, 50s wiring, etc.
Ahhh.. the brother from another mother. or the same mother.
Big beefy neck, bigger than any of my other heritages. SD '59 pickups (long leg). Sunsetburst finish. Tophat knobs, vintage amber switch tip. mmmmm good.
forgot to mention: this one has a nice beefy 50's style neck (by my estimation) and Seth Lover pickups. you can see the vintage style tuners.
... one piece solid mahogany body. No holes drilled in it for weight relief or chambering or other such things. And it still only weighs 8.2lbs
Ok I'll stop now
ThroBak SLE 101 Plus Pickups.
So you say vintage specs means a big neck? that is a MYTH!!! I had seen real late 50's Les Pauls and they don't have the big necks that people think they have. Real 59 neck is a no shoulder rounder shape neck but not as deep as what people think and even the 58 is still same kinda round profile but not deep!!
I remember those REAL late 50's les pauls having neck only a tad deeper than the early 90's les paul classic which was supposed to be a 60's neck!!
Wow - might be setting a record there. What year? And did you order with a spec on weight?
I bought it used, it's a 2003 guitar. First thing I did when I received it was take the control cover off to check if it was an LW model. I weighed it more than once, several times actually, and checked the digital scale.
My 137 is heavier at 9lbs. Luck of the draw maybe, or perhaps the original owner specified a lighter guitar :dontknow:
Skydog52~ That is one sexy 150!!
Skydog what is that finish called? I dig it!!
Of course you dig it. It's frigging amazing! Brockburst?
Thanks guys.
I call it a Duaneburst
