mark555 Posted March 11, 2014 Posted March 11, 2014 I have an old carlsbro 150w pa amp which is great, but seems to overheat. This is strange because it is a transistor amp. Everything works, it just stops producing sound. Can any one here with technical knowledge shed some light on this for me? I put it away last week and when we switched it on again a week later it worked fine until after an hour or two is did the same again.
SouthpawGuy Posted March 11, 2014 Posted March 11, 2014 Just a guess ... it may be overheating. maybe there's a fan inside not working, or there is dust blocking an inlet / outlet.
peterbright Posted March 12, 2014 Posted March 12, 2014 I agree check the fan and make sure the vents are unobstructed.
mark555 Posted March 12, 2014 Author Posted March 12, 2014 I know the 300w model has a fan, thanks for the tip, I will look at it as soon as I can.
bolero Posted March 13, 2014 Posted March 13, 2014 maybe a good idea to blow the dust out of it with a can of compressed air, dust will inhibit any heatsinks etc if it were mine I would bring it to a tech though! whatever is causing it to overheat might be causing damage...or it might not even be overheating
mark555 Posted March 13, 2014 Author Posted March 13, 2014 Thanks for the tips, I will take it to tech. It is really a very good amp for what I want it to do.
