Administrator Posted March 15, 2014 Posted March 15, 2014 On 3/15/2014 at 7:25 PM, DavesNotHere said: The same thing started happening to me a couple of months ago. When I access the site from my Windows 7 machine, I can not use the quote function or paste links or text. Previously these functions worked for me. When I use my XP machine, everything seems to work just fine. (using the XP machine now) There is a known issue with IE11 and the editor library that IPB uses. I've made a change to the global template to see if we can work around the problem. Can you log out, clear your cache, log in and see if it works now? No guarantees.
DavesNotHere Posted March 16, 2014 Posted March 16, 2014 On 3/15/2014 at 11:39 PM, Administrator said: There is a known issue with IE11 and the editor library that IPB uses. I've made a change to the global template to see if we can work around the problem. Can you log out, clear your cache, log in and see if it works now? No guarantees. Whatever you did it seems to have worked. I can quote and post a link. Thanks!
