Bigsby & Vibramate on H150?
Shmockiebaby
Has anyone out there installed a Bigsby B7 with the Vibramate V7 adaptor on their H150?
http://www.vibramate.com/vibramate-v7-lp-install.php
It is designed for a Les Paul, but I am wondering how close the dimension are between the LP and the H150 (from tail end of the guitar to the tailpiece studs). I'm thinking it should work.
Anyone have any experience with this installation?
Thanks!
Sorry - I should have searched first!! I found an example from another post. It works! Thanks.
If I ever wanted a Big on a guitar, using a vibramate would be the first thing I would try since I wouldn't want to drill holes in my guitar.
  • 3 weeks later...
I have drilled holes for Bigsby installations many times. I just like the subtle action of the Bigsby. And when I'm ready to commit.....
Most of the time it has been on one of my many Gretsch guitars, and the B5 holes sometimes even line up with original tailpiece screws. But on a H140, it's a different story.
I just used Vibramate for the first time today. Works pretty well. Lined up just a little bit crooked - but that could have been a misaligned strap button hole from the factory. Just slap it together loose, and then tighten it all down. Worked well on my new (used) H140, and easily reversible.
I used a B5 & vibramate on an H150, worked great
there was a bit of space at the back because the top drops off, but it worked fine & was only noticeable if you eyed it horizontally, up close
