Replacing a Reverb Tank
CJTopes
Does anyone know if I can replace a type 9 tank with a type 4?
The one that I'm replacing is a 9BB3C1B. I cant seem to find that one but there are some 4BB3C1B tanks to be had.
Any Ideas if I can do that and what the difference is between the two?
The 4B is an exact replacement EXCEPT it only has two springs instead of three like the 9B. This is subjective, but in general I prefer the sound of a three spring reverb for the jazzier stuff I play. Others like two spring reverbs for a classic surf music sound. I've had success repairing broken reverbs as well, if you really want to keep what you have. But a replacement 4B can be had for less than $20 so there's really no economy in that. Good luck!
Accutronics Reverb Codes
Reverb Type
1 Short (9¼") 2 spring unit
4 Long (16¾") 2 spring unit
8 Short (9¼") 3 spring unit
9 Long (16¾") 3 spring unit
Input Impedance
A 8 Ohms
B 150 Ohms
C 200 Ohms
D 250 Ohms
E 600 Ohms
F 1,475 Ohms
Output Impedance
A 500 Ohms
B 2,250 Ohms
C 10,000 Ohms
Decay Time
1 Short (1.2 to 2.0 sec.)
2 Medium (1.75 to 3.0 sec.)
3 Long (2.75 to 4.0 sec.)
Connectors
A Input and Output Grounded
B Input Grounded, Output Insulated
C Input Insulated, Output Grounded
D Input and Output Insulated
E No Outer Channel
Locking Devices
1 No Lock
Mounting Plane
A Horizontal, Open Side Up
B Horizontal, Open Side Down
C Vertical, Connectors Up
D Vertical, Connectors Down
E On End, Input Up
F On End, Output Up
